Wheel Width Question?
rtdakota
Looking at a set of CCW SP500s and have decided on 19s all around. Will be 8.5" fronts and want to go with 10.5" rears and want to know if they will fit with no problems.
Thanks in advance. :beerchug2:
if the off set is correct u should have no issue
spiral281
Zachary, La
you can easily fit 9.5 wide in the front, and 10 in the rear...widest i have seen is 10 in front (roush) and 11 in the rear (steeda)
smoken1986
Lynchburg, Va
Yeah as long as your offsets are correct you will be fine. I run 19x9.5 in front and 19x10.5 in the back and the car is lowered and have zero problems
