19COBRA93
Ford Racing
You may want to let the guys at Ford Racing and some of Ford's engineers know, since the 3v's do indeed have an oil cooler. Ever notice how on the track oil temps track within about 10 degrees or so of coolant temps? You can thank that nice, efficient little heat exchanger that is an integral part of the oil filter mount on the block. It also brings the oil up to temp quicker in cold weather.
You really need to check your facts. 3V's certainly do NOT have oil coolers. If you're referring to the adaptor that bolts to the block, that is not an oil cooler or exchanger. If you'd like to see an actual OEM cooler, look at any of the 4V's. They all have them (4.6 and 5.4), and are very different from the 3V adaptor.
3V = No oil cooler from the factory. This is a fact.
