Which strut mounts ???
Vcoat
Branford, CT
I would like to correct the negative camber which is more than i like now that the skinnies are on ...I am dropped on steeda sport lites...i also have the steeda camber bolt and plates which is maxed out so i guess i need the upper strut mounts but can't decide between these two ?...The J & M one adjusts out 1.8 degrees wheres as the steeda goes to 1 degree...not sure how much a degree effects things...also the J & M one is almost 50 bucks cheaper..
http://www.jegs.com/i/Steeda/957/555-8120/10002/-1?CT=999
http://www.americanmuscle.com/2005-caster-camber-plates.html
Sam Strano
I keep Steeda HD's in stock because I feel they are the best street setup. They are more quiet than any setup that uses spherical bearings and offer less impact harshness too. And price wise they are more than competitive. I sell they form $259/set.
J2L06GT
NW Ohio
If you want a cheap way to get back about 1* of + camber
turn the top plate of your stk mounts so the arrow is pointed in
instead of out, the hole for shock is offset 7mm so by doing
this it moves top of shock out. Since you already have camber
bolts you should be able to adjust for whatever you want from
there.
I run H&R Sports, 1" drop with no other adjustment bolts
and I'm at -.7* on both sides just doing this. If cambers were
equal before drop should be = with just spinning plates.
