whipple dyno video
Tiddies
life in the slow lane
Howell, MI
got my final numbers.
572 hp and 463 tq. its probably a little less because they took out some timing due to a fuel pump issue. i need to get a fuel pump because mine got maxed out at 5500 RPM.
video:
dyno sheet:
mods are:
built motor (9.4 CR)
comp cams 127350's
2.3 Whipple 3.00 pulley (15 psi)
black diamond monoblade throttle body
10% OD crank pulley
kooks long tube headers
corsa mufflers
4.10 gears
b00stedgt
New York
how do the 4.10s feel with that much power. You must be able to break em lose pretty much at any speed
bullittrevor
Nice! Talk about a flat tq curve. Got any SAE #'s?
Tiddies
Howell, MI
I do not have SAE numbers, if someone can tell me how to convert them i can tell you guys
bullittrevor
I think they run about 3% lower...but Im not exactly sure so I thought I would ask. If I am right it would put your around 555rwhp and 450rwtq SAE. Again Im not 100% sure and a lot depends on the humdity, temperature etc so there's no clear cut conversion you can do but 555rwhp sound about right for your mods. Guys with 2.3 whipple/head/cam/full exhaust and a built block usually dyno around 575-610rwhp depending on boost. Your car is a beast none the less.
Swarzkopf
Wow, that is a NICE curve. Awesome. Car has to be a blast to drive.
