Whipple install assistance
07GTTOM
maybe after loading your whipple tune (or in the messed up aftermath), the equizzer code changed. you need to find out that code from that stragey and make sure it matched the tune you have in the car now. the equizzer code needs to be correct in the tune or it will crank, but not start. just a thought
firestang70
SW Ohio Ninja
UPDATE. Well the pcm I got online to replace mine was no good (now to see if their warranty claims are legit). I got a new pcm and had them load all the stock info needed and VIN etc. The result.... It started and no issue other than the obvious engine light. My tuner is locked to the other pcm so it won't load my Whipple tune on there. I get tuned Mon or Tues, so good news. Also props to Mike@Powerhouse. He has first rate service, he was willing to try and help me out over the phone. I HIGHLY recommend his shop for any of your Mustang needs.
Rygen
I can break any motor!
Glad you got it sorted out DAle. I can't wait for you to get it tuned and on the track.
