Wire Tuck Thread
Discussion in 'DIY Tech Guides' started by W3bb3r04, Jul 23, 2013.
  1. Scott
    Scott Senior Member S197 Team Member
    2,332
    28
    Excellent start Kyle, looks great!
  2. LAStang1234
    LAStang1234 ----------DSL----------
    10,396
    36
    Bump!
    [​IMG]
    Sent from my SAMSUNG-SM-G890A using Tapatalk
  3. swflastang05
    swflastang05 Back for More
    2,032
    66
    [​IMG]
    Bump x2! (not nearly as clean as LA Stang but still much better than before!)
  4. LAStang1234
    10,396
    36
    I need that Stage II setup of yours Kyle.
  5. LAStang1234
    10,396
    36
    Starting on the GT500 today. I dont think I'm going to be able to move the fuse box since it doesn't have separate wiring connections like the 05-09 GTs.
    [​IMG]
    [​IMG]
    More to come...
  6. LAStang1234
    10,396
    36
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  7. Mustang97
    Mustang97 Junior Member
    Hey i have a big question would a wiring harness off a 2005 4.0 work with a 2006 4.6
  8. LAStang1234
    10,396
    36
    Bump...! Sold the White Shelby before I committed to the wire tuck, but now I'm on my second Shelby and am fully committed this go around.
    Probably won't do the fuse box since it'll require just about every wire to be cut, but I'm only 2 hours in so who knows at this point lol.[​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    Scott and 05stroker like this.
  9. Taxman
    Taxman One foot out the door
    6,652
    Looking good!
  10. Scott
    2,332
    28
    Good Luck!
  11. TylerM
    TylerM Junior Member
    30
    Just had a look through this thread. I am installing a KB 2.6 on my '05 GT and have planned on doing a tuck and really cleaning up the engine bay while I am in there. I have a question. The only reasonable way that I can see to get the fuse box moved is to completely cut it out and splice it back in at the new location. Is this best practice or am I missing something?
  12. swflastang05
    2,032
    66
    Yes that sounds right, it's been a couple years since I did mine but IIRC you can unwrap and re-route one of the harnesses with just a couple extensions (injector harness?), and there's only a couple wires to extend in another (headlight harness?), but you pretty much need to extend the main harnesses to the new location.
  13. TylerM
    30
    Thank you. I am moving the fuse box into the cabin and ecm to the fender like so many others.
    Sent from my SM-G960U using Tapatalk
  14. swflastang05
    2,032
    66
    Good luck!
  15. TylerM
    30
    Thank you, I will post pictures of the end result with the blower installed.
  16. TylerM
    30
    Almost ready to solder. Got another wiring harness for free so I am looking at how to use that in this project as needed. Last picture is the product of some light compounding by hand using a Meguairs compound. Looks like I will be doing the entire bay, between the tuck and installing the KB.[​IMG][​IMG][​IMG]
    EBABlacknChrome likes this.
