WOT box trouble
tnsaleen
Nashville, TN
Just got my WOT box installed. My car is stock with the exception of a O/R x pipe, and the WOT box.
Upon start up after install, I noticed my check engine light was on. I figure it was because I had removed the battery for a few hours. Followed the instructions, and it hit the 2 step fine. I go to drive it and it won't hit. Shut the car off, restart, hit it fine. As soon as I start driving it won't hit 2 step. However, it does feel like it is working on WOT shifts..
Any ideas?
Sent from my XT1254 using Tapatalk
NUTCASE
Wiring.
Did you do any tests with the car on without the engine running?
Test it with the motor off and look back over your wiring. Make sure everything is where it needs to be and the connections are good.
tnsaleen
Nashville, TN
Everything works fine when the engine is off, key is on. I ran through the trouble shooting procedure as well. I am fairly certain the all my connections are good, I'm decent an soldering and heat shrinked everything.
I might run a continuity test, and ohm the wires out tomorrow after I figure out what's up with the check engine light.
SNKPWR
Lake St. Louis, MO
I thought the two step on the wot box only worked when stationary? That's how I remember mine being on my 07 anyway
NUTCASE
The wot box does not know if you are moving or not.
Wes06
Wotbox does a launch control, redline limiter, and no lift shift
I think the difference between launch control and no lift shift is the order you hit the pedals
Clutch then gas =launch control, gas then clutch = no lift shift
tnsaleen
Nashville, TN
Just an update for everyone that helped. I downloaded the program and looked at it. I unchecked the lockout RPM, and everything works as it should now. I know without a doubt I had done the wiring right.
Thank you for the help guys!
