- Joined
- Apr 5, 2007
- Posts
- 6,356
- Reaction score
- 58
After reading this...
I gave Livernois every chance to make things right before I told anyone anything but the clock has ran out so I might as well share my story of some seriously fucked up business dealings...
For those that don't know, I got a set of their type 'R' racing heads. These were supposed to be the 'best of the best' in heads. These things cost me 3 thousand dollars ON TOP of me giving them back a perfectly good set of their stage 3 heads so I am into these heads for a whopping 6 thousand dollars.
At the time I got the heads, there were some claims being made about Livernois fudging flow numbers and I went out and had the heads flow tested at my own expense to help Livernois out and, admittedly, give myself some piece of mind.
On ininitial startup, it was discovered that the drivers side cam which was a 'special' Livernois grind brand new from comp was bent. This is at startup, brand new heads and cams. I sent the cams back to Livernois and after 2 months, I finally got word from them that comp agreed the cam was bent and warrantied them and gave me a new set of cam shafts.
During this time, I pulled the heads completely and had them inspected. Turns out they were damn near destroyed at startup from the bent cam. The drivers side is complete trash and the passenger side is maybe good for a salvage for some parts at best.
This is the last email I received from Mike Schropp where he acknowledges the damage from the bent cam they sent me with the brand new heads...
I'm sorry, but as I replied to him, 'ARE YOU FUCKING KIDDING ME?'
So I am out 6 thousand dollars on a set of heads that came fucked up and got 2 minutes of use out of them. Heads that were already acknowledged to have a bent cam from day one (that nobody seemed to catch mind you) and I am just OUT OF LUCK? I'm not even mentioning the fact the bent cam also cost me a 12 thousand dollar motor.
Friggin' ridiculous...
My biggest regret over the years is not just shelling out the money in the first place and going with JPC/RGR from day one. I would have saved a ton in the end. I will not let anyone but Rich Groh or Justin Burcham ever touch my car again...
On our end we would probably not easily be able to sell them. We try to not deal anything that is not a first hand item just because it avoids any possible complications. I would agree that the bent cam probably did a fair amount of that damage and caused that head to go south quick.
At this point though I don’t see how we could repair the damage to the one head because of how extensive the cam tower damage is. The galling and aluminum damage is pretty bad. So it seems as that only really leaves us with one good head. We could take that one head that is good and just clean it up and some basic freshen up stuff on it so you could sell it. On the other bad head however I would say we could salvage the parts used in it but we would need to go through and do another casting up to match the good head.
Is this something that you would want to do?
Thanks
Mike
