I'm going to move some of the posts that I was making in why TB are expensive thread to my YSI upgrade thread since my posts are getting more on the tech side of TB and injection plates and really don't pertain anymore to prices of TB's.
Has anyone compared the performance increases with these throttle bodies and have some dyno graphs to show these gains? Would be nice to see 4-5 of these aftermarket TB in an actual side by side test. IMO listing of upgrades by performance impact I would place TB's on the far end of the list, you probably gain more hp putting a clean air filter on.
That being said the stock TB seems to get lots of corrosion especially if your injecting meth. This 4yr old BBK TB I use doesn't seem to corrode at all, I just took it off tonight to fit this Snow Performance Injection plate and it's clean like new.
Too bad this Injection plate failed to fit.
I'm going to take a chance on the GT500 TB without the spacer upgrade kit, I want to use this meth plate as the spacer.
I just don't know if the nozzle on the motor side will fit. The BBK TB I have will not fit the nozzle on that side.
I stopped by a local Mustang shop today and put the plate to a Stock TB and it clears, from the pics the the two GT500 and stock are very similar on the motor side.
Stock
GT500
GT500 spacer plate
This Snow Meth plate is probably made by NX as it seems other parts from Snow have NX labeling. I could save some money with just the TB for $125.00 or punt if its not compatible and go stock.
By spring I'm going to do an actual comparison of a stock TB, a BBK TB and the GT500 with adapter, side by side same day dyno runs and see what's what.
I just got in the GT500 60mm TB which I was going use with a Snow Performance injection plate.
It doesn't fit so I ordered the BBR GT500 adapter and will drill it for the 2 meth jet and use that instead of the Snow Performance plate.
The 60mm GT500 TB has more spacing between inlets than the BBK 62mm so adapter needed. From the picture of the adapter it reshapes the inlet closer, once I get that adapter I want to see if its still 60mm.
The Snow Performance plate will not fit the 62mm BBK without grinding, you need also flip it upside down as you will take less material out of the TB then. This BBK TB has lots of metal you can take away, I found this TB to be a real nice quality TB that doesn't corrode from meth use.
After grinding the meth jet and spacer plate line up perfectly.
A comparison of the BBK 62mm top and the GT500 60mm Bottom.
I just need to get a good stock TB, the Snow Performance Plate fits the stock without any modifications.
Then will test on a boosted 4.6 3v with a YSI-B supercharger.
Update:
Now that the injection plate fits the TB I bolted it up to the intake manifold and now WTF moment. Seems the rubber o ring gasket would leave a gap in the center both top and bottom, I know I can seal that up but it seems strange that this plate was made this way since Both the FRPP and the stock seem to have the same rubber No#8 shaped o ring gasket.
Injection plate adapter on FRPP intake manifold.
I don't have a stock Intake Manifold but this pic I found of one sure looks like the same shape.
Update:
Fitted the GT500 throttle body tonight, drilled out the TB and installed BBR's adapter plate. Right now I have about $185.00 total in the GT500 TB and BBR adapter. Tasca Price for the GT500 TB was $104.95 complete ready to bolt with electronics, BBR adapter and hardware $80.00.
GT500 TB drilled out and BBR adapter on, bolt sleeves align the two.
Snow Performance Injection Plate added to the BBR adapter.
Installed, I'll need a little bigger 90deg elbow reducer since the GT500 TB inlet is larger than the BBK, was pretty hard to get it on.
Hood check.... Everything fits with the stock hood closed.
