Wild White Pony
End of last year I decided to switch out to a better Centri Blower, the Vortech v3 Si was just at it limits of 18# and out of breath. Since November I have been adding supporting mods before I purchased the unit, including ID1000 injectors, S&H Hat to Rail fuel line upgrade, Fore fuel rails, KB 20vBap, Second Meth Jet and a custom 3.5"Inter Cooler piping setup with a custom Inter Cooler from S&H Performance that has the maf housing built in and a remote IAT sensor in the Intake Manifold so I can read the air with meth.
Well after waiting for a month my YSI-B showed up on Wednesday, had it ready to tune on Thursday.
I'm loading this with pics if anyone is interested in doing the same upgrade. I was just tired of the original 3" vortech setup and constant tuning problems having the maf located in the intake pipe before the TB. The new Radiator support for the Inte rcooler eliminated the original radiator support and freed up a ton of room.
This is a really easy install and inexpensive to boot, I think I have about $850.00 in it right now for the inter cooler,silicone couplers, clamps, Remote IAT sensor and piping. The BV and mounting flange I took from the original 3" pipe.
Original V3 setup.
New setup:
Old Rad Suport vs new support with Swaybar mounts
S&H Performance Inter Cooler and Mounting Support
3,5" Inter Cooler with Maf flang and original Vortech AA Inter Cooler
Tial Q50 BV
Sway Bar Mount, Plenty of clearance
Blower down pipe clearance.
Intake up pipe clearance, no problem with the A/C or Tensioner
Inter Cooler Support
Remote IAT Sensor
Plenty of ground clearance
Will update with more info and parts used, heading out to dial in the MTF. All of the piping was stock Vibrant you can buy online and only needed 2 pieces to be welded.
Original V3 setup.
New setup:
Tial Q50 BV
Remote IAT Sensor
