Whoa, who, whoa.... KCBrown.... you are massively over-thinking a lot of this stuff!!!
By chance,
are you an engineer? Please take all of this knowing that I respect your thinking, but feel that its all overblown and off base. You talk about roll couples and roll centers and geometries... camber curves, and ruining the car by lowering it. I got about halfway through your post and my eyes crossed... your logic and debates hurt my brain and
I actually understand this stuff, have an engineering degree, and design suspensions for a living.
Please stop writing so much and relax a little.
Honestly, some of the stuff you write is way off base, and you are confusing people with a lot of technical jargon that is mostly meaningless
in these situations (not Formula 1) or that are blown way out of proportion. This over-thinking, propagated via the internet forums, is how so many people get confused into buying bad parts, or learning things that are the opposite of fact. This is how shops sell lots of "bump steer correction" kits, tubular control arms and K-members, subframe reinforcements, bolt-on braces and other useless doo-dads. Over-analyzing problems that don't exist or that are so inconsequential that they can be ignored. Magic shock frequencies, roll couples, migrating roll centers... those are all well and good on an F1 car, but we're talking about two steps up from a horse and buggy with this chassis.
The number of formulas, graphs, charts and confusing terms in my reply will be zero. Why? Because none of that "calculating" really matters on these cars because they are SO compromised in so many ways.
KCBrown here is one of the VERY few people on this or any enthusiast automotive forum who would continue to run OEM springs, stock ride heights, and skinny tires on purpose. I suspect he is 1 in 500 that does it for anything other than budget reasons, if I were a betting man.
I need to make a video of what driving a STOCK late model S197 Mustang HARD on track looks like. It is TURRIBLE. It will give most people motion sickness, and it is EXTREMELY unpleasant to drive like that for very long stints on track. In my position as owner at Vorshlag and an instructor for many autocross schools and HPDE groups, I get to drive
hundreds of Mustangs - and more stock ones than I want to. The S197 chassis is
not "God's Chariot" in stock form. It's not a good handling car - it is a big, heavy, tall, soft marshmallow PIG of a car.
Luckily it has one main saving grace: it came with a big honkin 5.0L V8 (unless you chose poorly) and pretty decent brakes (Bembos). That's why I bought our 2011 - when the Coyote came in it, now it was worth using. The platform itself has a very rigid chassis and decent enough "bones" to work with, too.
Quick and Rude Mustang Facts: the GT500 is worse in almost every way. The Boss302 is not special or magic, its just a bunch of stickers and a few dood-dads slapped onto a 5.0L Brembo car that a real track driver will toss in the trash (Tokico shocks?!). The V6 is not worth buying unless you are a middle aged secretary and the automatic should be banned. hehehe...
The S197 V8 cars are not alone in this predicament of being "terrible handling cars in stock form". And I don't care what magazine journalists have to say about this car - they only get to drive OEM unmodified rubbish cars, anyway. There are other, heavy-ish modern cars with decent power that come with crap suspension from the factory. The top of the line EVO X MR (above) was a JOKE in stock form. 3610 pounds (very similar to the 2011-14 V8 Mustangs) and yet it had soft springs and tall ride heights with skinny stock wheels (17x8") and tires. It felt like it was going to flip over and I would have sworn we were dragging the door handles in that first autocross event where we ran it with stock springs/shocks (above).
And just like with the S197, we made it handle better with improvements to spring rates, shocks, bars, bushings and lowering the ride heights. But unlike our "over the top" TT3 Mustang, we kept this one street friendly with moderate spring rates (450#/in) and no aero mods. Like our S197 formula, this car got the same basic upgrades: 18x10.5" wheels, 275mm tires, more spring rate, lowered by 1.5 inches, good monotube adjustable coilover dampers (AST), and camber plates up front. To help control roll it also got adjustable swaybars, and of course a few power mods. It was a LOT more fun to drive and it won a lot of races and even set some NASA track records in TTA. There are dozens of useless doo-dads and "fixes", available as parts from the aftermarket, it did NOT get, too.
The stock S197 is similar in almost every way. Too tall, too soft (springs and bars), skinny wheels (18x8" or 19x9") and tires. It has big sloppy bushings and soft rubber strut top mounts that allow all SORTS of camber loss under loading, toe change under braking, and makes for a big wonky mess when pushed hard. All of the formulas in a suspension engineering book get thrown out the window when the wheel is moving laterally 1/2" due to hydraulic bushings! Add more mechanical grip (tires) while keeping all of this stuff stock and it can get downright ugly. It might work for somebody going really slowly, but not real enthusiasts, track junkies or autocrossers - unless they like painfully sloppy cars that eat tires at an alarming rate (ie: Stock class SCCA competitors).
Look, you are NOT "ruining" these cars by lowering them, if you do it the right way. Lowering the CG is one of many ways we make this chassis corner harder (look it up) and LESS of a floppy, sloppy parade float for track or autocross use. Sure, there are considerations that must be looked at when you lower the S197, and you CAN "over-lower" this and any car. When the ride height is lowered more than 1/2" from stock you should:
1. Add rear LCA relocation brackets to improve the anti-squat
2. Go to an adjustable panhard bar or watts link to center the axle (it shifts laterally in one direction at ride height when lowered)
3. Increase spring rate and/or shorten the damper lengths to prevent loss of bump travel
4. Check bump travel and trim bump stops accordingly
That's not rocket science, and its not as complicated, detrimental or dangerous as some interweb posts would have us believe. Again, I think someone along the line spooked kcbrown about lowering cars, or he read some over-blown article explaining the evils of lowering. Its just not that terrible of a thing, and the factory suspension geometries just aren't that good to begin with on this car.
In the 1960s and 70s, lowering a car could put it into some wacked out camber curve that GAINED positive camber as suspension went through its motions. But those cars were beyond terrible even in stock form - some of those old muscle cars have NEGATIVE caster, went into positive camber under cornering (above), and virtually all of them had weird problems and terrible static and dynamic geometries. And even the 19880-90s Mustangs were fairly terrible, but they could be made better than stock with the right aftermarket parts.
Even the S550 is soft and sloppy in stock form! But we can make those better, too
The S197 is a lot better car than any previous generation Mustang, in every way except weight. To compensate for the added mass we use THE BIGGEST TIRES MONEY CAN BUY and every increase in width helps. There is NO downside to bigger tires on these cars, except if you spec the wheels wrong and run out of room (rubbing).
But to say that "brake dive isn't necessarily bad" is patently absurd. Look at this stock 2006 GT under braking at an autocross and tell me "that looks fine."...
That's Jon's Mustang (above) when it was still bone stock, with the OEM springs and shocks. It was TURRIBLE.
Turrible, turrible, turrible! The massive brake dive transfers too much weight to the already over-loaded front tires (due to a heavy front weight bias), and reduces braking potential dramatically.
Now here is the same car and driver HARD on the brakes on track, after a spring upgrade (550F/250R), new shortened housing dampers (MCS TT2), adjustable camber plates, wider wheels (18x11") and wider tires (295 Rivals). Its over 2" lower than stock, and has the fixes above we say help (LCAs + brackets, adj panhard bar), but nothing else it doesn't need. It still rides well, is still daily driven, but it is MUCH faster in autocross and track events and a LOT more fun to drive. It also wears tires dramatically better, doesn't have 5 degrees of tilt cornering and 12 degrees of brake dive when stopping. Everyone who rides in this car at an event wants to buy the shocks it has. Every. Single. One.
So anyway, that's my response to the "over-analzing" and "stock is safe" arguments of others. No offense is meant, just want people to keep things in perspective and not be AFRAID of lowering or modifying their cars, with the help of real suspension experts that understand "what matters and what doesn't". We work on a LOT of these cars and have made hundreds handle better without getting into the extremes we do on our TT3 car. The above two Mustangs have our suspension upgrades, handle better, and lap times went down as smiles got wider. None of them worried "Are my camber curves ruined?!", they just trusted the source and had fun. Isn't that what this is all about?
Cheers,
