ArizonaGT
Road Course Member
Seat time, seat time, seat time.
But seat time can be had in any vehicle. It doesn't require any suspension modifications at all.
So I suppose this raises the rather interesting question that I don't recall ever seeing asked:
What suspension setup on the Mustang makes for the most effective learning platform? Which is to say, what setup will make that seat time count the most?
200tw tires, bilsteins, good brake pads/fluid/lines. And go have fun.
Based on your experience with the Konis versus the Bilsteins in terms of their damping, would you say there's a substantial difference between them in terms of their effects on learning? The Konis have the advantage of giving you knobs to experiment with, and that can be useful for learning, but not if the damper itself somehow gets in the way of you being able to feel what the car is doing.
I know your experience with the reliability of Konis was not a good one, but that shouldn't affect your answer to the above, as long as there was some period of time during which the Konis worked properly.
I know what I'll get with the bilsteins every time I get in the car. I think from a pure driving technique stand point the non-adjustable dampers aid in learning how to drive the car. It keeps me from getting distracted and playing with the knobs every run to the point of adversely effecting the handling. Taking out the user error variable on shock tuning has definitely helped me at this point in my driver development.
What I wonder is: how can you tell that you're in the bump stops? I suppose it's not really something I'm going to have to contend with much because I'm on 280 treadwear tires (Bridgestone S-04 Pole Position) and plan on keeping it that way as long as I'm having fun while driving on them. They're certainly inexpensive enough...When I start getting into the bump stops consistently when cornering I'll step up spring rates and dampers via coilovers.
It's the inconsistency thing that bothers me here. But I guess if you get them dynoed, you can adjust them so they're all about the same, and then at that point it becomes a question of whether or not they'll maintain their damping characteristics.I've never said the Koni yellows didn't "work". I only said that for me they were inconsistent and didn't last.
Yeah, the durability question is a big one. I guess the biggest problem with the Konis is that you can't immediately tell if one is blown or not unless you have enough experience to know the difference by feel. Most people probably don't have the kind of precisely calibrated instrumentation (e.g., rear ends ) to tell, so the failure rate of Konis could easily be vastly underreported.I'll take blame for not having them dyno plotted but beyond that the durability issues are on Koni in my opinion.
Makes sense. I guess you could get the same effect by having the discipline to not change the adjustable shocks, and just initially set them to something that people with experience say will work well (I did mine based on math and dyno plots, but the end result is close to what Sam Strano would normally recommend).
It sounds like as long as the Konis aren't changing their behavior at a given setting, they should do the job. Then once someone with them gets to the point that they can comfortably start changing the response characteristics through the knobs, they'll be able to. But then, by that time, it might be time for coilovers anyway!
I'd love to ride in a Brembo Mustang with stock spring rates and Bilsteins, just to see how much of a difference there is in the way the damping works between the two.
Several ways.What I wonder is: how can you tell that you're in the bump stops?
Generally agree . . . with the caveat that it is at least possible to have a chassis that's too advanced for the driver regardless of the tires.I would say the most effective learning platform is the one that's best behaved on the worst tires.
The trick with having adjustable dampers (or sta-bars or relo brackets for that matter) is to make an initial setting and leave the damn things alone until you've got a better idea what you want or need.I know what I'll get with the bilsteins every time I get in the car. I think from a pure driving technique stand point the non-adjustable dampers aid in learning how to drive the car. It keeps me from getting distracted and playing with the knobs every run to the point of adversely effecting the handling. Taking out the user error variable on shock tuning has definitely helped me at this point in my driver development. When I start getting into the bump stops consistently when cornering I'll step up spring rates and dampers via coilovers.
That's not to say you have to leave your competition damper settings the same as your street settings, only crank them up to whatever and leave them alone for the duration of the event. A test and tune event is really the place for experimenting with different settings anyway.
Norm
I wish I would have known some of this information prior to buying koni struts and shocks for my fox..... Now ill be worried that the stuff is gonna break quickly on it. Especially since it will always be a track car
unfortunately I got about the best thing ( to my knowledge) for my fox that I could. THe next thing is custom coilovers and I just really dont want to spend $3-4k on a set.
I really think the blown Koni thing is massively overstated. Have had them on numerous cars without issue. Shocks don't last forever on a race car.
