Understeering? Get rid of those itty bitty 245mm fronts!
hehe.... we have sold a LOT of S197 guys a LOT of sets of 18x11" wheels. And lately a lot of 19x11" wheels for people that cannot understand that 18" has better tire choices, or they don't like the look of 18s. But for CAM class, with as unlimited as it is? I'd shy away from anything smaller.
Going with an 11" wheel and a 295-315 front tire will add MONSTER cornering grip up front and likely kill a lot of that understeer. The other keys to reducing understeer include:
- Real spring rates up front, starting at 450 #/in and up to 550-600#/in on wider street compound tires for CAM. We tend to AT LEAST triple the stock front rates, for openers. This reduces brake dive and front roll GREATLY. Nothing else can make up for the lack of front spring rate... not a bar stiff enough to add 300 #/in in rate!
- Run REAL dampers to work with REAL spring rates
- Run more negative camber if tire wear or measured pyro temps look bad on the front tire shoulders
Just wanted to
note: The 2015 CAM aero rules have changed radically.
Page 230 of the 2015 rules. Rear spoiler may be added, but may extend no more than 8” from the original body nor past the perimeter of the body. No rear wings may be added except OE or equivalent. There are also some MAJOR changes elsewhere... so check the rules.
Previously allowed CAM mods no longer listed in the rules, and hence assumed now illegal:
- Rear wings?
- Steering columns?
- Changes to exterior mirrors, lights and trim?
I used to run CAM in this Mustang with a stock engine... no longer legal on many counts. But I could add a twin turbo monster motor, custom Corvette suspension, and carbon brakes - and all that's fine!
edit: Like have been saying lately: don't build around SCCA class rules, especially for a brand new category like CAM. Of course you should run their events where your car fits - they have the most competitive autocrossers in the country there - but the rules for many classes are a quickly moving target, and
sometimes that target does not include logic or market considerations. This has been getting better lately (with some long overdue updates to rules affecting Mustangs in ST, SP, and Street) but they have a long way to go and a lot of years to make up for...
Cheers,
