Ready for the Track Tomorrow.
TurboPete
Miami, Fl
Cant sleep , ready to go to PBIR tomorrow night . Ive been chasing gremlins for like 2 or 3 months with the fuel system and more boost . I think its figured out tomorrow will tell .
With more power comes more tuning the shift points , but I think I have it under control .
Hope to see Lethal and BBR out there tomorrow . I want to see the BBR Turbo 2011 make a pass .
I hope the weather holds up and that it cools off a little . The weather here in Florida has been horrible for racing , humid as f(*& and raining in the afternoons.
I hope it all works out and that I see a full clean pass at 26.6 psi's .
Stay tuned for results.
Pete
TurboPete
Miami, Fl
Ok not the track day I was hoping for , Ive just about had it with these new pumps that have come out . Bottom line is they dont work. Yes the Aeromotive 340s , and Deatschwerks flow more fuel , but they loose the flow numbers drastically as the temps go up. Its the only thing I can think of . In the last 2 months I have gone thru 6 pumps, and re-wired the entire fuel pump wiring from 10 gauge to 3 separate 8 gauge wires , 3 separate 40 amp fuses and 3 separate Bosch Relays . Today 1st pass off the trailer at low boost held fuel pressure until almost the end of the track when it locked converter then I notice that the a/f went to 12.6 so I lifted . Car felt off right from the start . Next pass added 5% more fuel and this time I looked at the pressure , dropped from 67 psi's to 50 and went lean again . Its the freakin pumps .
So 3rd pass I jumped the hobb switch to run the 3rd pump right from the start , car felt awake in the burn out box , John Force style so I knew it had more pressure . Left the gate with a 1.48 which is down from my normal 1.40s but felt better until I blew the intercooler pipe off .
Air/fuel was still in the 12.2s so I know its the pumps will loose pressure .
So now the plans change again , getting bosch 105 injectors and Walbro's go back in . The 105s will give me 20% more fuel flow which will allow me to drop the rail pressure down to around 38 or 40 , and I will be able to run 26 psi's of boost and still be around 67 psi's of fuel pressure so the Walbro's will still be good .
Im so frustrated right now this will be the 3rd time I drop the tank and replace fuel pumps .
Took a few video's tonight but nothing worth posting other then a real nice burn out.
Should get the injectors tomorrow and put the pumps in by Sat.
Pete
silverpoison
SoCal
Have you datalogged the voltage? I know of a few people that runs a bap on return systesm to keet the voltage on the pumps consistent at wot. They not run a pick up tube wusing your current hat and just slap a magnafuel pump or a aeromotive? I really don't trust all those small pumps over a proven high volume fuel pump.
TurboPete
Miami, Fl
What injectors are you running now, ID 1000's still?
Still on ID 1000s , was going to pull the trigger on the 1600s but they are having issue's with flow when they get hot , the 2000s work great but thats way to much injector for my needs . Im getting the 105s and running the Walbro's again . The car ran great for a year no problems on the Walbro's .
Yeup , believe me I check everything on every pass, Voltage 13.4 to 13.1 all the way down .
Its the pumps , I let the car sit for an hour and made a pass it ran better and pressure stayed up , just blew the intercooler pipe off so scratched the run .
I dont really want to sump the tank and put a Fuel Lab / Magnafuel , etc on there . The Fore hat keeps everything nice and neat.
I have thought of a surge tank set up,but thats just more crap in the car.
Walbro's are reliable I just need more room with injectors, so I can turn up the boost to 26 psi's .
We've been debating on making a custom factory fuel hat to drop a fuel lab pump in the tank , but at this time I dont really have the time to mess with that to make it work . Not sure if it will be too much for the factory baffle in the tank .
I'll post up updates as I go along.
By the way Jared from Lethal was at the track with there 2012 Boss. I'll let him post up results , but it ran great . Wow!
Pete
TurboPete
Miami, Fl
Ok ready to swap out injectors soon, has anyone sodered the wiring harness before or just buy the quick connect plug and play, any thoughts which is better is appreciated .
Got the pumps already and waiting on new fuel socks which will be here tomorrow.
Re-tune next week.
Pete
Redfire
Hey Pete,
I would solder them in instead of running the adapters. It is one less connection to worry about.
ChevyKiller
Preferred Internet Drink
Pete
Pete - you have crossed the threshold IMO where it is time for a TRUE return system (I say 'TRUE' meaning not a kit on the stock system but a 'real' big boy pump and injectors)
Honestly bro - the more power you go for the more and more you are going to continue to give yourself headaches trying to run through the CPU
Just go to a BS3 system already and save yourself lot's and lot's of headaches in the near future. Where you are heading - you are going to end up having to go to a BS3 anyway so you might as well do it now and yourself yourself the misery to come if you don't.
Your life would be so much easier with a BS3 - I promise you.
TurboPete
Miami, Fl
Do any of you drive the car everyday in bumper to bumper traffic , stop and go , in 90* humid weather . I dont think so . Yes STAND ALONE is the best for tuning and racing I know this , Ive known this since the Haltech and Accel DFI days. One of my best friends who got me into racing is Willie Figueroa . He was racing and building bad ass mustangs before any of us even had an idea in our heads about cars. Ive learned alot from him and he tunes my car . Its not my 1st rodeo guys.
Eventually I will go stand alone , but not until I stop daily driving the car . When its just a weekend hot rod then I'll take the jump .
If I sump the tank and run bosch pumps I wont have any pressure issue's , but by sumping the tank now I will have low fuel issue's . Wont be able to run the tank down to or close to E.
Lets see what happens after I try the new injectors , if it continues to drop pressure there has to be something else wrong . It never dropped pressure with the Walbro's before . All the problems started when I tried these new turbine 300+ lph in tank pumps . They get hot and drop off pressure .
Pete
