I believe I sent you my fan connector didnt I? lol
Sure did! Still keeping things cool!
Sorry, not trying to push the issue of flow. Only said to look originally, but we got OT.
For lo pro, these are the best thing I have found. Low cfm rating, but work better than anything else. Cheap flat blade design, not even the good style, but really works well. Pulls more than other I have tried rated at over 3000 cfm. I see surface temps on the rad drop over 40 deg in about 3 sec.
http://www.summitracing.com/parts/SUM-G4852/
This one doesn't cover the whole radiator, but works well on mine with 1k hp. If you had the room you could also get a cheap shroud made out of aluminum and it would work even better. Probably get one made for 40-60 bucks.
If you can fit these, you better hold on.
http://www.summitracing.com/parts/DER-16927/
Then the derale will be your man. It really is stupid how much air it moves. Next upgrade for you, and alternator lol.Lo profile isnt an issue for me at all. That setup from summit looks badass lol
hope so, if not i see new fans in my future lol
haha wonder if it would help my IAT temps too, lol. I already got twin fans on the HE though.
Im sure it helps keep my fmic a little cooler while im sitting still and the fan is on high. But yeah if you have fans on your heat exchanger already im sure there isnt too much room for improvement. Do those fans run all the time or at a certain temp?
Yeah I mean im torn on it bc the bullit style grill only has openings in the honeycomb near the center/core like the stock grill to help force airflow towards the core. But a more open grill will let more air in overall to cover more surface area.
