vinnybarber
The converter is not the only reason you do that for
Never tried it with a 4R70W and just don't know, but is there a way to use a converter bypass like on the glides or th400s?Even with proper spacing setup the converter can, and will, balloon if he is on the transbrake too long.
Yes
You won't. Nothing to balloon. You're fine with a manual transmission.
I almost o-ringed my block while I was in there.Oringing the block and using SCE titan gaskets. .043" thick.
I have 3.750 in stock but they wont work with a normal style oring. I would have to figure 8 it. I will have to order the other set tomorrow.
For those of you that dont know what Oringing a block does is it pretty much takes away any room to fail in the head gasket territory.
You take .030 of a groove out surrounding the bore and install a stainless steel wire in it making a perfect ring. You want to put the ends where both part of the ring connect as close to a head bolt as possible and make it perfectly flush. Then you use a SCE copper gasket and when you torque the head down, the stainless steel crushes in the gasket. After talking with my tuner (Lito) we came to the conclusion that where im going with the 88mm that it was a good idea to do.
Now where is the next weak link, LOL.
I started to pull my heads apart and clean them up and do a 3angle job to them. I have to replace all the guides cause they are very loose. The exhaust were the worst, due to the 2 piece manley inconel valve that Livernois uses. The inconel disperses heat, but the second half of that valve thats steal doesnt and passes the heat to the bronze guides causing them to loosen. Typically you would want about .0015 clearance. I only have about 4k miles on these heads.
Holy Shit Paul,when will you have all this back together?What happened to a 10.50 daily driver/bracket car?
Randy, my heart wants to go fast and my pocket and reality wants to dial back and run a index class. Since I had the car apart, I set it up to handle what I can throw at it, in case something changes and allows me to really do what I want. I will make some new passes with the new new motor and converter to go faster than the 9.66 141.
It should be running tomorrow after noon. I just have to pick up the converter in the morning and install the trans. The motor is back together for the 3rd time, hopefully I have this thrust issue fixed with the trans. I really am thinking that it is the cooler lines that did it.
...just...wow...
I learned the hard way; I cant do it myself, im outta my league.
Verry interesting/impressive build.
Amazing build...
Yea Chad, it sucks when you get it back together and think that the motor went from sitting on the transbrake too long. I thought that time after time, sitting on the brake just ate the thrust bearing. I was wrong, I changed trans lines and it took the block, pistons, and crank out. Well when I took it apart, I realized that the Livernois stage 3 heads had shitty guides put in. They were on the way to take out my seats if I left them in any longer. They were pretty bad. I recommend to everyone that has a set of Livernois heads to check out the guides. and see if they are going bad. I know Lito had issues with his guides also.
Just curious, did you check trans cooler line pressure before and after changing them out? I'm glad you got it fixed and it was a simple fix.
