jayman33
Lets see, today I will be buying the Dynatech driveshaft, lethal h-pipe and the JLT Big air CAI for my whipple. I bought the whipple a week ago however, I won't be installing anything until Feb/ Mar :( Next up, exedy clutch and spec flywheel, amazon tune, pulley, RTRs or Avant Gardes, LCAs and sways but those aren't til next month.
Albuquerque, NM
A word of advice that was given to me a while back from a fellow forum member "Look closely at the background before snapping the picture and make sure there are no porta-jons in the shot"
ya, i know, was wondering how long it was gonna take for someone to see it. Had to get in and out of there with the quickness. People didnt appreciate me using the handicapped ramp to drive into their park
new front 2pc rotors and a fresh set of TR6s
Thanks Ron-94tbird for the help.
Scott
King City, Ontario, Canada
It retains the sway bar as well, right? I was looking at some others that are lighter, but have no brackets for the sway bar. Since drag racing is not my "passion" I will not be taking the sway bar off at least not permanently.
Yes, that is the reason I went with the Steeda rad support. The part number is 555-5075.
Scott
Installed an Aluminum MOROSO Brake Reservoir Cover:
wht67
Jenks, OK
I actually did it yesterday but didn't have a chance to post.... Finished my Whipple install and started her up to purge the air from the coolant system. Only idled to get up to temp but it was a great feeling to start right up after such a big mod. I also wired in the relocated IAT sesnsor, finished the wiring on my gauges and made up a firewire cable to hook into the SCT X3 for including the wideband in datalogs. Now I'm just waiting for my tune so I can drive!!!
psycho bob
FISTER
Tulsa, OK
picked up a 2010 6060 and everything needed for the install. trans, crossmember, driveshaft, pro 5.0 shifter, stock shifter, reverse lockout wiring, and super king cobra clutch.
assasinator
1000hp turbo 4v
well the direction is decided. 1.625 primaries.
headers:
they are just tacked. have to start somewhere. two more tubes on this side.
number 5 will merge directly into the 2.5" pipe.
where the tubes from 7 and 8 join, the tubing steps from 1.625 to 1.75".
BMWM3
Always Online
Cordova, Tn
Well this weekend I finally spent all day installing a few thousand dollars worth of parts on a friends car (He and I spend ALL day saturday from 7:00am to 12:00midnight .. but we got it done.
Installed Navigation/dvd/Satellite/Bluetooth phone system radio
Installed speed of sound Triple pillar pod, wideband, fuel, vac/boost
Installed rear sway bars with end links
Upgraded to 14 inch brake kit with pistions
Stainless steal brake lines for the front
installed slp Line lock
installed nitrous system on his car
1 piece steeda drive shaft
Centerforce dfx clutch
centerforce flywheel
hd slave cylinder
4.10 gears
detroit locker
Barricade
Decepticon Extraordinaire
The Alamo
hd slave cylinder
4.10 gears
detroit locker
Will u be my friend??? lol
Do you have to remove the hood to take those back engine bay plastic rain gutters off? Any tricks??
BMWM3
Always Online
Cordova, Tn
we had to remove the hood b/c we drilled into the plastics things to put the duel purge on it one on right side and one on left side. .... each purge out is on the plastic behind the windshield washer thingys.
MindIfISmoke?
Wrecking Crew
Puyallup, WA
I scooped up
Zex blackout kit
Zex purge kit
Zex window switch
Sequential plug and play tail light kit
All for an excellent price from fellow board members
Sent from my DROIDX using Tapatalk
My08Stang
One Bad Poster
Cape May NJ
Loaded the 5.0 onto the trailer to run down to JPC in Maryland tomorrow and let them have their way with her ;)
