tigerhonaker
TN
Loaded it on the trailer and headed to NMRA in Bowling Green
Have Fun and Good-Luck
tigerhonaker
keith88lx
Mt. Prospect, IL
UPS dropped off my CHE LCA brackets.
Got an UPS email delivery update and this is the note from the UPS guy.
Driver Release Location: MET CUSTOMER MAN
CPRsm
^^ Turbo car baby !!
Got me a 4 wheel alignment. And put the back seats in.
SRTthis
Abingdon Maryland
put mine back together in 20 minutes from intake manifold to air filter set the idle and took it around the block... you'd think ive done this before
filled a bunch of nitrous bottles at the shop for the race car and plugged a hole in a tire on the rzr
MadStang
Corner Carver
Escondido, Ca
Using aircraft paint remover to remove the sound deadening so I have a clean spot to weld my cage in place.
Replacing the battery lead since it's no longer tightening down to the terminals.
Also replacing my JLT intake pipe, somehow mine collapsed.
MadStang
Corner Carver
Escondido, Ca
Is that an effective method?
yup comes up in a slab versus crumbling. I only recommend it in a highly ventilated area, with a mask on and gloves. This stuff is highly volatile and will burn your skin as well as the smell will knock you on your butt if inhaled for too long.
