need help with wheel offset!!
TX_JC_GT
Houston TX
hey i need some help with wheel offset. im looking to buy the xxr 522 in 18x8.5 and 18x9.5 i need to know the correct offset for my stang.
the 18x8.5 have a +30mm or +48mm offset options
and the 18x9.5 have +25mm or +38mm offset options
i want them to be flush with my fender or almost flush so i can use a spacer.
any help will be greatly appreciated
TX_JC_GT
Houston TX
so the 18x8.5 +30 and 18x9.5 +38 will be good? just double checking before i buy the wheels online.
Hey man I answered your pm but didn't notice those are your offset options, based on that if you want a flush look I would go +30mm up front use a 255/40 tire and a 10-15mm spacer that will sit perfectly flush. The rear I would go either +25mm with a 275/35 for flush or the +38mm and use a 295/40 for that beefy look which should also sit very flush. Either way post pics when you get them installed:)
06gtmustang316
Fayetteville, Arkansas
Ive always wanted some Rota Grids, but they didnt come in a good enough offset. These looks sexy though, and they resemblethe Rotas really well. Go for and post pics. wonder if they fit big brakes....
peetiewonder
Terminator
SFV, CA
+25 on a 9.5 with a 275 will rub. 275/35/18 will also be a miniture ass tire. 275/40/18 would be more appropriate.
This is 19x9.5 +24 with a 275/40
EVS6351
Tucson, Az
Definitely agree with the lower... But looks great! What offset did you end up with?
DRock
you need a hell of alot more tire. Should of just gone with a square set up
TX_JC_GT
Houston TX
+30 front +38 rear. the tires were extras i had laying around. m saving the money for fatter tires now
