Road Race Suspension///
ESP v6
kw v1
gms adjustable bars front and rear
steeda adj. pan hard
ce pan hard brace
mm bumpsteer
ebc yellow up front and red out back
battery relocated
245/45/18 RE 11s all the way around
still have a steeda adj uca waiting to be installed
frank s
at Play
Paradise
Hm.
FRPP "P" springs
Koni yellows
Steeda adjustable front stabilizer bar (shortest arm)
Steeda front stabilizer bar bracket stabilizers
Strano/UMI adjustable endlinks
GT500 Brembos / Hawk HPS
H&R 26mm rear stabilizer bar
Steeda adjustable Panhard bar and brace
GT500 SVT 18x9.5 corner anchors
4 x 285-40 Goodyear Eagle F1 (not the sticky KR ones)
06GTMustang89
Corner Carver
Cary Area, NC
Front:
BMR Tubular K Member
BMR Tubular A Arms w/ A arm support bar
Steeda adj. front sway bar
GT500 Struts
Steeda Ultra Light springs
Brembo brakes w/ dba slotted rotors and hawk hps
GT500 strut mounts
BMR HD boxed subframe connectors
Rear:
Hawk HPS
QA1 shocks
Steeda ultra light springs
Steeda Panhard brace
BMR adj. Panhard Bar
Wheels/ tires
18x10 FR500 w/ 285/40 Nitto NT555
18x9 FR500 w/ 275/40 Sumitomo HTRZII
shocks are next on the list once i have enough dough for koni yellows and CC plates.. overall very pleased with the setup
Cheyne
Iowa City, IA
My current setup on my SCCA Touring 3 2011 Mustang V6 is:
Ford V6 Performance Kit Springs, struts/shocks and swaybar.
Ford Adjustable Panhard Bar.
Ford Racing LCAs.
3:31.1 (per rules) and Torsen T2R diff.
17x8 stock wheels from a 05 GT with Hoosier 245/40 R6 or A6 tires.
Race Technology DL1 Data Logger and Dash Pro 4.
Stock Brakes with customer pistons in the front.
Carbotech XP16 front and XP8 rear pads
Boss 302r Radiator along with a remote oil filter/cooler setup
CATs removed and semi custom exhaust.
Class weight is 3575 with driver.
For 2012 I'm moving up from T3 to T2 due to class realignment.
In T2 I will use:
Anze Custom made struts/shocks with Penske inserts.
FR500 coil over springs
Custom exhaust from Angry Sheep Racing
Custom engine tuning also from Angry Sheep Racing
3:55:1 rear gear
18x10 Ford Racing BBS wheels with 295/35 Hoosier tires
Reduce the weight to 3500 with driver.
Brembo brake kit.
Cheyne Daggett
Mr. WHO
Saint Peters, MO
Ford Racing LCAs.
In T2 I will use:
3:55:1 rear gear
Brembo brake kit.
Cheyne Daggett
Sweet to see a newer 3.7 being tracked. How is it compared to the 4.6 or 5.0 on a open track?
darkstar november
magical turning mustang
ft lauderdale fl
my old 08 i sold in jan
steeda sport springs
Tociko dspec shocks/struts
MM CC plates
steeda adju front, non ajdu rear sways
steeda adju 3rd link
steeda tubular lcas
steeda adju panhard bar
oem 3.55's
2000 cobra r wheels in 255 NT05's
thats what i can think of off the top of my head
new car
for now, tociko d specs, but Koni yellows are on the truck and will be here 1st week of jan
steeda sports
UMI lcas(got them for cheap)
gt500 wheels with 275 khumo 's
coming after christmas
strano adju bars
hawk dtc 60/30 pads
CC plates
Sleeper_08
Mods on my 08 GT;
Roush S/C 445 HP
Enkei PF01s 18 x 9.5 x 35 mm offset
275/35/18 NT01s
Steeda Competition springs
Koni Yellows
FAYS2 Watt's Link
UMI Poly/Rod LCAs
Steeda Adj UCA & Mount
Steeda Upper strut mounts
GT500 Front LCA
Steeda X5 Ball Joint
Steeda Bump Steer
GT500 Brake Kit
Carbotech XP10 F/R
Quantum Front Brake Cooling
Cheyne
Iowa City, IA
I'm going to create a post for the project, but against the 5.0L the couple times we have been on the track together, in 2011 they were in T2 so we didn't run together, they dominated me off the corners and in a straight line. For 2012 the 5.0L has had a extra 150lbs of lead added and the intake restrictor reduced from a 65% to 50% to slow them down.
Cheyne
Mr. WHO
Saint Peters, MO
Cheyne
Interesting and Ill *post* any other comments in your new thread.
Norm Peterson
corner barstool sitter
RIP - You will be missed
ESP Norm! Bring that thing out! lol
Yep, that's where it's belonged for a year or so now. Shown here at NJMP for the only event I made it to last season (non-SCCA).
picture.php
Most anything more that I do chassis-wise to suit what I want in my non-competition driving will end up shipping it off to CP.
darkstar november
ft lauderdale fl
ive been running esp for a few years in this and my last car, i actually just got the email, i won 1st place for season points in esp for my region this year
jayel579
North Jersey
I know it is a drive for you but you got to try to make it to an event at Giants Stadium. The lot is very worth it!
silverstangz
Clermont, fl
Complete stock...except for:
Tubular Front Cradle
SLA Tower Set
Bump Steer Kit
GR40 Lower Street Steering Shaft
Steering Rack Set
SLA Tubular Front Lower Control Arms
SLA Street Front Upper Control Arms
X5 Ball Joints
Upper Ball Joint Adapter
Koni SLA Street Coil Over Kit
Griggs Tubular Anti-Roll Bar Kit Zero Bind
SN95 Spindles w FRPP hubs
Agent 47 Brake cooling kit and lower ducts
Torque Arm
Aluminum adjustable LCA's/Heim jointed
Griggs relocation brackets w/305 kit
Griggs Axle Bracket
Koni Rear Coil-Over Kit Spring 250#
Griggs Shock Support Bracket
Griggs Anti Roll Bar Kit, Rear
Griggs Watts link with adjustable roll center
Torsen T2 w/3.73 gears
Jongbloed 305's 18" x 10.5" forged wheels with Hoosier R6, 315's
this list just sounds like alotttt of fun !!
knownukes
South FL & Oak Island, NC
08 GT-500 Super Snake
-3.6LC Kenne Bell S/C(700.43rwhp)
-John Lund tune
-Baer 6 piston calipers F & R
-Hawk DTC 70 front/60 rear
-Revan Racing/Shelby Cooling system(radiator and heat exchanger)
-Griggs power stering cooler
-Griggs 4 point roll bar
-Sparco harness
-Torsen T2R w/3.73
-R6 295/30/18's on all 4 corners
-Yellow adjustable coil over Koni's-front
-Eibach front sway bay
-adjustable camber plates
-Griggs GR40RT rear chassis system
torque arm
Watts link
Coil over springs
Adjustable length control arms
Anti roll bar
315 tire adaptor kit
-Rehagen Racing tow hooks F&R
-4" brake ducts
Philostang
Chrome Hater
Chicago
Well, since she’s a perpetual work-in-progress, here’s a snapshot of the current performance goodies.
Suspension:
- Agent 47 SLA (Race version: tubular LCA w/spherical bearings)
- Penske 7500 coil over shocks (single adjustable, front)
- Hypercoil springs (front)
- Koni Yellow shocks (single adjustable, rear)
- H&R Race springs (rear)
- MM aluminum rear LCA
- Steeda LCA relocation brackets
- Steeda competition rear UCA w/HD chassis mount
- Fays2 Watts link
- Modified OEM front sway bar (per A47 instructions)
- Strano adjustable rear sway bar
Chassis:
- Steeda radiator support
- Roush strut tower brace
- CHE K-member brace w/torque limiters
- Prothane engine mounts (set for 3/4” drop)
- Jacking rails (fabricated to receive side skirts down the road)
Brakes:
- Stoptech ST40 calipers w/14” 2-pc rotors
- Carbotech XP-12 pads (front), XP-10 pads (rear)
- Carbotech Bobcat pads (fr/rr for street)
- Ti Speed titanium heat shields (front)
- Fabricated front cooling ducts
- OEM rear calipers w/Hyperfirm lines and OEM rotors
- Motul RBF600 fluid
Wheels/Tires:
- Enkei RPF-1 wheels, 18x10”
- Hoosier R6 (275/35-18) or Continental race scrubs (285/645-18)
- ARP wheel studs
Interior:
- MM 4-point roll bar w/diagonal brace
- Kirkey aluminum deluxe road race seats
- RaceQuip 6-point camlock harnesses
- Ecliptech Shift-I sequential shift light
- FRPP Boss Mustang steering wheel (w/adapted wiring harness)
Engine:
- CAI/Tune
Next Up (this year):
- T56 transmission (Viper spec)
- Aluminum driveshaft
- Fidanza aluminum flywheel
- RAM HD clutch
- Tow hooks (front/rear)
- Fabricated rear spring mount for 2.5” o.d. springs
- Repairs…"oh, `tis better to have had traction and lost it than to never have had traction at all"
And let that be a cautionary tale to those of you starting out on tracking your car! The needle sinks deep kids, just look at Uncle John, and Uncle Dave, and Uncle nuke, and Uncle pcdrj, and…ah hell, we’re all down with the sickness.
Best,
-j
DRock
^ I would love to watch that thing race
ArizonaGT
Road Course Member
Phoenix, AZ
Ran my BOSS stock (with the exception of a strano adjustable rear bar and some camber plates) for just about a year now, going to put on the following suspension parts in the next couple weeks:
  1. Roush Trak Pak suspension kit
  2. FRPP Poly RLCAs
  3. FRPP RLCA relo brackets
  4. J&M Adj. PHB
  5. MM Bumpsteer Kit
  6. Strano/UMI Adj swaybar endlinks
Very fond of the PF01/PF97 combo for brakes using the stock calipers and heavy one-piece rotors. Will likely go to Girodisc 2-pc rotors in the future. Brake ducting already installed.
FR500GT
Orange County, CA
How she sits now:
-Saleen Speedlab N2+ adjustable coilovers
-Saleen front sway bar
-Saleen front big brakes
-Motul RBF600 fluid
-FR adjustable panhard bar
-Forgestar CF10 wheels
-Michelin Pilot Super Sport tires
In the works: custom front brake ducts and rear 14" upgraded rotors, front splitter and rear diffuser.
