bradleyem
Several times now my car has done the following: When starting for the first time after it has sat for awhile...
1st crank - it cranks, stumbles a little bit, then stalls
2nd crank - it cranks stumbles at first then idles up and runs. BUT if I press the gas pedal it stumbles and stalls again.
3rd or 4th crank - It starts right up and runs rough for a couple seconds, but then smooths out and runs great with no hesitation.
The second time that it did it it took 4 times to get it started. Once it was running I pulled out of the garage, shut it off and read the codes....no codes were found. It started right up after that.
So, with no codes I'm thinking maybe bad gas or the TPS/Throttle is getting ready to go....but I'd like to figure it out before I get stranded several hours away out of town.
