Going For 800 Rwhp
lostsoul
2014 vett or 2015 stang..
Gay Area
I can pull the motor and have it torn down in about 6-8 hrs by myself in my garage at this point
where the hell were you at the last 3 times I needed to take mine out..haha
I need your skillz =-/
TurboX
Formally Buzz Lightyear
San Anto,Tejas
Billy this sucks and I am sorry to hear, you have a great attitude and I look forward to reading about your return.
I know you said you have a sleeve, I know a guy with a 2010 stock short block who would prob let it go for low price, pm or call me if you need it.
Hawgman
THE fucking bad guy
What regulator were you using?
This is the one I have on mine.
psfracer
billy badass
Valencia, CA
That is a good regulator.
OP--so your regulator has a boost reference port? I would think you could have it tested. OR perhaps its a problem with the boost reference line itself?
05stroker
Never enough power guy!
Bullard Tx.
Practice makes perfect. LOL
Thanks , but a sleeve is $100 installed and I have used them many times. The are as good as new as far as I concerned.
Sorry to hear. I gave up on mine when I did the same thing last year. Kudos to you for keeping going.
I wont lie, there for a moment there was about to be another BB ford conversion happening here.
I have a Fuelab unit #51501
Damn dude, glad your in good spirits!
What else ya gonna do?
Yes it does have a boost reference port. I still need to inspect the lines and fuel setup. As of now my mind has been on buying parts and getting the block back together. Once I have the parts and the piston is at Polydn getting coated, I will dive into the issue. I have not touched the car since I took the block apart and saw the damage.
I think the only reason I am not more pissed right now is becouse the motor needed to come out for the rear plate leak, 127550 cams and springs, and I wanted to inspect the bronze guides to see if I wanted to go back to steel or not after the failures I have been reading about with the bronze guides. I will know more on that tomorrow.
05stroker
Bullard Tx.
Also for those that order the Manley Billet I-Beam rods. You need a Chevy rod bearing. Part number is Z82020cp and not the 4.6 part number Z87250ch. These are Federal Mogul (Sealed Power) part numbers. FYI
2005wantAB
Tennessee
By the way this is my favorite. Mirror image of the cabinet in front of the car.
Damn thats a pretty hood!!
05stroker
Bullard Tx.
Lots of pearl in the new paint. It looks awsome!
And to update:
I really wish my piston was as important to the guy that took the order from my machine shop, 1.5 weeks and find out yesterday that they have no record of it!!! Oh well new order with Race Mart done tonight. Should be here Fri or Sat. Then to get coated. Ryan at Polydn said they can turn it out along with the new bearings and the other pistons on that bank in 2-3 days so I am looking at next weekend instead of this weekend to assemble the motor. The block is back in the garage with the new sleeve and I will pick up the heads on Fri. with the new Comp springs installed for the 127550 cams. I had the machine shop go through the heads and check the bronze guides since there seems to have been some issues with them on others cars and they are fine. New seals and springs and they are good to go.
I am still really puzzled as to why this happened in the first place. I for the life of me cannot figure out why the waste gate and fuel regulator never saw the boost. I have all the vac lines running from the bottom of the JPC intake and am thinking maybe there was some sort of stoppage that blocked the lines. I am open to suggestions here.
Beaumont, Tx
I just finished with my f1 build, I hope you dont have a problem with the vacuum lines from bottom port of the jpc manifold because I did the same for my fuel rail pressure sensor and brake booster. The fuel regulator, b.o.v, & boost gauge were done in 1/8 inch plastic line coming from the 1/8 piped hole on drivers front of the manifold. I wanted to use the plastic line with compression fittings to make sure under 25+psi they don't blow off lol When I ran my vacuum lines I was digging through here to see how you did yours. Hope you get the problem cured sir
05stroker
Bullard Tx.
Not real sure at this point. I will look into the vacuum lines more this weekend. I'm thinking about a braided line from the side of the intake to a vacum block and then rubber hose to each accessory with no tees.
Beaumont, Tx
Yea the braided line was a thought but I wanted to go small and flexible for easy and fast concealment. I thought about doing a vacuum manifold under the intake but I worked it out.... Not near as clean as your engine bay though lol
05stroker
Bullard Tx.
I would most likely need to hide the vac manifold, but the area under my intake is almost as full as the pass side dash. LOL I will have to study it some. If there is a line from the side of the intake it will have to be braided. I have a 24" -4 line in the garage and some -4 fittings, so that may be the starting point.
