MindIfISmoke's? Built Part 3.
JeremyH
3V Fuel Guru
Virginia Beach
I'd do a wot box before the nitrous. 2-step, no lift shift and it has a window switch feature as well.
JeremyH
3V Fuel Guru
Virginia Beach
I pioneered something I like to call the rolling 2-step as well. Works pretty good. I can downshift and engage the 2-step to build a 4-5 lbs of boost in a split second and then clutch out and take off. ;) Good tires are a must for this though lol, Instant torque!
jodadejss06gt
TEAM DELETE SHIT
Severn MD
Matt I'll see if I can get my go pro directly on the boost gauge this weekend at the track to show you 2 steel and wot shifting.
supergenius
so a 3 step.... Is that not common inn the v8 world? "we" set stuff up to retard timing, full throttle shift witrh dog boxes. jyust keep her to the wood, timing gets cut enough to stick it in the next gear but keep the motor spooled.. :O) Is that not an option?
JeremyH
3V Fuel Guru
Virginia Beach
:wtf: lol
Wot box has the 2-step and no lift shift to cut timing and not loose boost.
