LAllison20
It is closer to 77k I guess
For starters, how many miles are on this engine? Springs get weaker over time.
because you have extra pressure in the cylinder when the valve is opening the pressure is trying to close it back. that is why you need a stiffer spring. just makes it easier to hold open the valve. i have the same problem with bbr regrinds. i just never really said anything, but i think it is the regrind cams. i broke a valve when it happened and lost 2 pistons.
We were talking about that; would there be any other indicators? He just did an oil change 2-3 weeks ago and no sign of metals....would there be a drop in performance? Would a compression test verify that?
Did you cut apart the oil filter to verify no metal?
Bobby is this on your new motor or a previous combo ?
It's a good idea when experiencing any kind of problems or concerns to get a filter cutting tool from summit and cut open the filter to inspect. It's a cheap way of catching something before it turns into something major.
Did you receive my last PM about the stock 3V?
