Whiskey11
SCCA Autoscrosser #23 STU
- Joined
- Feb 24, 2012
- Posts
- 1,644
- Reaction score
- 4
Among the many things I learned yesterday at the autocross (including the fact that Chris Conant's 1988 M3 is 4.5 seconds faster than me =\...) is that with my set up, I'm still getting a fair amount of push. To the point of having probably a little too much grip in the back that throttle on oversteer is basically non-existent in second gear without upsetting the car violently somehow (parking brake).
Here is what is done to the car and what settings various bits of suspension are adjusted to)
Steeda Sports (200 lbs/in front rates and 175 lb/in rear rates, 1" front drop and 1.25" rear drop)
Tokico D-Specs (3.5 out from full hard on the front, 5 out from full hard in the rear)
Strano 35mm front bar (set in the stiffest position)
Strano 25mm rear bar (set in the middle position)
Fays2 Watts Link (prop bolt in bottom hole)
Steeda HD Mount (Alignment at -1.7º camber, neutral toe, +7.5º Caster)
Dunlop Star Specs in 245/45/18 (31 PSI front, 32 PSI rear)
So, the question comes up, which bar would be the best to change to dial out the understeer? I could take the front bar down to the middle setting and give up some steering responsiveness and go further into positive camber in hard cornering (sadly already doing that) or take the rear bar up and risk an easier to upset rear end. I am looking for some thoughts from people who know more about which would be the preferred bar to change for autocross. I'm thinking the obvious choice is the rear bar to leave the front bar to add some needed spring rate.
And about that 4.5 seconds! Talk about embarrassing (not really as I was expecting a severe schooling)! I'm not sure this car will ever make that up with the wider tires and wheels, CAI, exhaust and tune, and a driver worth a hoot but that is what it would take.
