New Brembo's Installed on the 13 CS!
Digital_Synapse
I see that now. Never thought that there wouldn't be a clear answer on which way the slots point. Car looks good.
It doesn't matter which way the slots on the surface of the rotor point. That is cosmetic. The vanes on the rotor are the inside of the discs. Some company make the slots run with others against the vane, either way, the vanes should spin as if they were "scooping" air. :)
The slots don't do anything but decrease heat sink capacity and look nice. There are no raised edges that contact the rotor so there is no "bite provided by the design. Just the surface area a d friction levels of the pads and the contact area. That said... They look sexy :)
The calipers look darker than the factory ones, and heavier grain of the texture. I like it a lot.
46Tbird
DFW USA
They look exactly the same as the stockers on my '12 GT.
Car looks great dude! When are the engine mods going to commence? :omfg:
04sleeper
Dallas, TX
Well done. Looks great. I was not aware that you could not order the Brembo with the CS package....
Yeah. You can get one or the other. Not both. :tdown:
They ARE the stock ones. I just cleaned them up a little. Hopefully should get started on the engine mods this winter.
flyfaster1
Nice, looks good.. i gotta see those rims at C&C soon though. Ill be there next month, hope to see your ride there.
BlackDragon
Large Member
Bronx, NY
How much did they set you back if you don't mind me asking?
I'm looking at getting a set as inexpensive as possible so i can get them custom coated...
Wicked5.O
'Stang Noob
Very nice upgrade and looks great with the rotors. So only around $900? That's not bad.
Rotors on the Brembos are free floating correct?
