Cost of Welding Axle Tubes
AJCrader
Glendale, AZ
I am wanting to know what I should look to pay to get my axle tubes welded, as I am by no means a welder, nor have I had to have anything welded.
Also, should I look at going to going to a rear-end specialist or what?
Thanks in advance!
drive_55_not
Thanks in advance!
I would guess a few hundred if you remove the axle and take it to a shop who knows how to weld axles, It needs to be done in stages to ensure the axle stays straight and the weld holds.
nitrobob
Missouri
I just paid 570 for gear install,weld axle tubes,install lca relo brackets and weld in,install of lca. HTH
JeremyH
3V Fuel Guru
Virginia Beach
This really depends on alot of things, get a quote, I would think 1-2 hours labor, labor rates vary alot.
No real negatives, welded on vice pressed on to the dif.
Seer
Zero negatives, I paid my guy $50.
There are plenty of negatives to not having it done though. My buddy with a 2011 GT/CS with a FRPP Whipple 2.3 was cutting 1.6's all night and he twisted one of his tubes. Had to replace the rear end.
white05gt
Illinois
Too many variables, some shops will want to remove ring and pinion in order to use a bar to ensure the tubes stay straight. Others will weld it with it together.
AJCrader
Glendale, AZ
any differences whether or not it is welded together vs apart?
assuming apart is better, but would still like to know differences
JeremyH
3V Fuel Guru
Virginia Beach
What differences? Both ways they get welded, one way will cost more for a little more peace of mind that they are straight.
Greg Hazlett
Stepping on the Pink Bus
Official Vendor
Chesapeake, VA
Rays197 just had his done along with a lot of other work, he may be able to tell you how much it cost.
Seer
You could also just buy the CHE Axle Brace as well.
Food for thought, I am planting 750rwhp down on a 28x12.50-15 MT ET Street, cutting 1.5 (hopefully faster soon) 60's. I just did the el cheapo axle tube weld method, and so far, so good.
Greg Hazlett
Official Vendor
Chesapeake, VA
Ray ALSO just bought the CHE axle brace so he is really making sure nothing goes wrong!
AJCrader
Glendale, AZ
Thanks again for the help, I think I might have to go to a local differential place and see what they say!
AJCrader
Glendale, AZ
Looks like it makes sense...I saw that one came with an axle girdle, is the axle girdle something I should get too?
Also what about a panhard bar? If so, adjustable or static?
Seer
Adjustable, even from the factory the rear end is slightly off center. Even more so after lowering.
rayS197
virginia beach, virginia
I cant tell you what the cost was for just welding the tubes as I had a lot of stuff done to the rear end and the invoice was not fully itemized. I cant see no more than $50 to $100 just for welding. If you plan on gears, a new differential, and welding the tubes it makes sense to have everything done at one time. Speaking with a welder by profession who runs around with us, he stated you dont need to put the axle in a jig to weld. Mine wasnt done in a jig, nor were some of the others I asked about. An axle girdle will help and make sure you purchase one that has bearing cap support. Here is a recent thread on this topic:
http://www.s197forum.com/forum/showthread.php?t=86648
matt06
St. Louis
for what its worth i have a brand new che brace i just havent gotten around to listing for sale as i have no use for it with the 9", lmk if your interested
