front splitters available? may have a solution but need pics!
Department Of Boost
Alpha Geek
Yeah, that sounds like a good setup. And the pricing is right. I have made a few splitters now and I would pay that so I didn’t have to do it again!:beerdrink:
Roadracer350
Tulsa OK
Do you make splitters that fit 2010 and up?
If I can get a new model to get a template off of yes. I only have 1 template right now but a buddy is a local Ford mech and I will see if I can get one made up. What kind of front air dam/chin spoiler are you running? If its anything like the CDC agressive this will work.:beerchug2:
Roadracer350
Tulsa OK
OK guys I am hopeing to have pics up by Monday. I have a 4x8 sheet coming today at 1630 and I will document it with pictures and post up!
POS VETT
Marietta OH
Holy hell. Screw the splitter, I want that cross brace !
Roadracer350
Tulsa OK
That wouldn't be that hard to make. I have a copy of this pic printed and while i'm under the car this weekend I will get some measurements. Simple enough piece. Majority of it can be Water Jetted out then just a little machining and tapping.
leviathon
Erwin, nc
I like this guy lol :beerchug2:
Roadracer350
Tulsa OK
:rock:Im all about if they say I cant buy it or its to expensive screw em im gona make it myself!! Unobtiamium? Pissh! Get me a pic and some measurments and watch the chips n sparks fly!!
leviathon
Erwin, nc
:beerdrink:I want 3 peice forged wheels for under 200 bucks!!
Department Of Boost
Alpha Geek
The back side (top) of that X brace is relieved (perfect for dropping tools/fasteners into!) to lighten it up. You would need to get it in a mill too.
Roadracer350
Tulsa OK
Here are a couple toys I made. one is a 6061 solid Golf Ball and the other 2 are a .50BMG rounds I made to see how they would shoot. I drilled the back to put a piece of tungsten in to give them a little more ompf!
zquez
Death Dealer
the sky
Well, how did they shoot? lol
Roadracer350
Tulsa OK
Pretty good actually! They still didn't have the same impact as the Naval Bronze/Tungsten I did but they did OK. They were around .125" grouping for 3 shots at 750 yards and about .375" at 1000. The bronze rounds kept their energy all the way to 1000 and had about .1875" with 3 shots. Here is a crappy cell pic with the short barrel on. I have since put on a 40" barrel and that's what I was using to get the numbers.
Department Of Boost
Alpha Geek
Love the golf ball! Those 50 bullets are pretty sweet too. I've heard that all the precision .50 BMG bullets have to be done on a lathe? Is that true?
I want a 50! Waaaaaaaaaaaaaaaaaaaa! Which one is that, I can't tell from the pic.
I got to run 10rds through a Barrett M107 a month or so ago. I know they aren’t as accurate as a bolt gun but being able to go “semi” for 5rds was life changing.:beerchug2:
When I get one I don’t know if I will go bolt or semi. Probably bolt. But I would like to have both.
Roadracer350
Tulsa OK
Its the Anzio Light weight .50. Yea to get good ones that will reach out their you need them made on either a CNC lathe or by hand on a manual. I make mine on the manual here at work or if I want say a dozen or so we have some Omni Turn Screw Machines that I program and run them.
