This seems like possibly you might be slipping into over-analysis? Not knocking that - it helps to stay on top of the tech and maximize your car, but the bolt-on braces and brackets don't really do a whole lot on a fully caged race car. I get where this stems from - so many companies make so many brackets and ding-dongs they it all must make the car faster, right?
I call this trap Steelitus (stolen term from others). That is when you are bolting on more and more bracing to the point that you are just adding more "steel weights" to a car. Steelitus is a very easy trap to fall into, but honestly, the S197 chassis is SO much stiffer than its predecessors (Fox, SN95) that even with ZERO brackets and bracing they are stiffer than the previous Mustangs that have every aftermarket bracket available.
While all of those bolt-on bracket doo-dads are pretty, they really don't make your car faster on a race track. Just heavier, except in the wallet.
If you have a caged race car you could probably chuck all of the braces in the trash and notice no difference. If you are doing consistent track testing - try it. Get some consistent laps in on a test day then unbolt all of this extra "accoutrement" and see if your lap times change at all. They might not change, but they might get faster - if you are removing significant amounts of steel.
I don't have any of this stuff on my S197, which we run on the same tracks and on the same days as American Iron racers. We're 3 seconds quicker than the AI track record (Boss 302-S) with an "un-braced", un-caged, 3750 pound daily driven street car. We just have wider tires (315mm vs 275mm for AI) and decent aero, on nearly stock engine. That is going against a field full of caged, stiffened-to-hell, dedicated race cars that weight 400+ pounds less. And we haven't seen any chassis or body cracks on the car, and it has no creaks or squeaks, even after two years of track use and 20,000 street miles. So apparently the stock chassis isn't too floppy sloppy?
I dunno... that isn't remotely a definitive test of bolt-on braces or brackets, and many other variables are at play, but it does make your wonder if any of that stuff is even necessary.
Drive it!
