Upper control arm & mount install question
fdjizm
Drag Queen
Just a stupid question but one I need the answer to.
Are you able to get the upper control arm mount back in with the upper control arm installed on the mount? is there enough space down there?
Because I can't see myself squeezing the arms bushing in the mount while it's on the car it's a REAL tight fight.
Either that or I am going to put the upper mount around a car jack and stretch it out a bit.
fyi this is a BMR upper control arm mount with a J&M adjustable UCA.
thanks!
BMR Tech
Traction Vendor
Tampa, FL
Yes, I recommend torquing the arm to the mount with the assembly out of the car.
fdjizm
Drag Queen
Good to hear! thanks man!
I PM'd you BTW need some info on the bolt that came with your UCA mount I didn't get it in the box (ebay reseller), just need the size I'm sure I can pick it up at the hardware store.
BMR Tech
Traction Vendor
Tampa, FL
I saw you PM'd. Sorry about that! I have like 80 pms to catch up on.
Here is what comes with the UCM001.
(1) HW152 M14 x 120 hex head screw, GR10.9-CZ
(1) HW002 M14-2.0 poly lock nut, GR10.9-CZ
(2) HW014 1/2 flat washer, USS, GR8, YZ
california gt
senior citizen member
R I
Hey Kelly, yes one of those PMs was mine and it just so happens that is about OEM nuts and bolts.
Specifically safely re-using them how many times and buying quality replacements.
Hardware store for nuts and bolts that are torqued to over 100 ft lbs and have other loads applied???
BMR Tech
Traction Vendor
Tampa, FL
You just want to ensure that you use a Grade 8 or higher, Metric would be 10.9.
As for re-using factory bolts, we have done that for years. I am not really sure how many uses to recommend, but I would say that 3-4 times of torquing to say 129ftlbs....and it may be good to invest in new ones.
fdjizm
Drag Queen
Well OF COURSE I can't find these parts anywhere.
Can I buy these off you?
one eyed willy
Pizzle fo shizzle
Lakeland FL
FYI...i just replaced my stocker UCA with the BMR mount and UCA.
I put it all together outside the car and installed it in one peice, easy as pie! To drop the gas tank, i didnt have the correct torx bit, i used a regular 50 bit and just removed it slowly with no issues, then replaced the torx bolts with regulaer hex heads.
fdjizm
Drag Queen
good to know I can assemble it and slide it in, drop the gas tank you say?
why!!??
drive_55_not
why!!??
Ya' gotta' drop it to get the mount out n' back in. I didn't need to fully remove the tank strap bolts when I did mine. Just back'd them out 99.75% and that gave me enough room to swap the mounts.
You maybe able to swap mounts without dropping the tank, but I wasn't.
Riptide
Will work for Mustang.
Montucky
AFAIK there is no way to do it without partially dropping the tank. We did it the same way ^ you did. I was surprised, my tank didn't just fall either. I literally had to wrestle that bitch down. It wanted to stay put.
Also, it's a torx plus bit to get the fasteners for the strap backed out.
fdjizm
Drag Queen
Apparently some people get by without dropping the tank, wtf.
I hope I can be one of those people lol.
fdjizm
Drag Queen
Alright so I found the elusive snap-on T50IPR (FTXR50TPE) torx plus bit on ebay and snagged it.
Sharad
Site Sponsor
Fort Myers, Florida
On my '06, I torqued my UPR UCA onto the mount outside the car. I had to lower (not remove) the gas tank to install them. Fwiw, after I loosened the straps, I had to hang on the tank and bounce to get it to separate from the body of the car. I was pretty shocked.
fdjizm
Drag Queen
^that shit sounds scary lol, so both straps needs to be removed? or just a little bit on one side?
lindertw
NoVA
I loosened both when I did it, and yea you have to pull on the tank to pop it free. Helps to have as little fuel as possible in it too...
fdjizm
Drag Queen
So take both strap bolts out and just tug that bitch? does it fall all the way down or just enough to slide the mount in?
