07TGGT
@user
Duh! I'm no Napoleon Bonaparte
So... Gizmo, have you noticed any change in temps since dipping the supercharger? I only started mine to check for leaks, but was just wondering.
LOL seats are easy to swap, along with brakes, and the track pack doesn't mean shit once you start swapping suspension. Torsen diff is nice though.
You're still a bitch for going with GT500s. There is other chambered mufflers out there lol
Nope, not a single difference. My IAT stays at around 50-53 right now, same as it was before I did it.
I totally think you could hold a torch to the blower and the intercooler will still do it's job, it's just so damn big, lol.
The charger gets hot, just like before, but no noticeable difference in feel when I touch it. PDip is good to 350 deg too I think.
The torsen diff will not handle the drag racing either. It wasn't meant to be hit hard like that with the added blower power. But he may only see a track a few times a year.LOL seats are easy to swap, along with brakes, and the track pack doesn't mean shit once you start swapping suspension. Torsen diff is nice though.
Need to start new thread. LOL.Who here is running the passenger side PCV to the intake manifold with either a catch can or a hose, WITHOUT the provided check valve in the kit?
Having a discussion about this with a buddy, need opinions. I have both sides T'd off to my CC, and then from my CC to the intake tube. Basically a glorified, no oily mist, vent setup. I feel that if I ran the OUT side of my CC to the I/M, without the check valve, I would be pressurizing the PCV in the opposite direction.
So basically, if you're running a JLT/whatever CC on the passenger side/boosted intake side, without the check valve, I think your wrong. It's like trying to fart while blowing air up your ass...
Prove me otherwise... Go.
i run both heads vented to atmosphere with a filter on each side and capped off intake manifold and inlet tube. no oily mess and seems work fine.
I am vented as well.Vented is the way to go, Im basically vented as well, just in a way that nothing can touch my pretty engine bay, cuz I'm scurred of mist, lol.
Let it dry up here.I would like some more incar Paxton videos
