Jeremy, what is maximum pressure for pancake tank that I should set?
what pressure would you recommend for best comfort?
and for best performance?
Leftie, who did you order from? I'm looking to get the same setup.
Sent from my SCT X3
Jeremy, finally we had some nicer weather and I was able to find my leak. Can you tell me specs on how tight MNPT fitting should be tighten to? Both my rear bags are leaking in the same spot and I am not able to find it in the instructions.
Also, what would you recommend for storing over winter, keep pressure in, or drop it and let all air out of the tank? (usually mustang sits in garage for about 4 months).
There is not a torq spec on that fitting. Did you wrap teflon tape on the fittings?
I will take another picture later today so you can see it.Ok, thanks! So close to fitting without modification, i bet i can figure something out.
That would be great, i dont start my install for a couple weeks but my kit should be shipping in the next day or too i hope.I will take another picture later today so you can see it.
Oh look at all the air in this thread.
I ordered the latest setup Tuesday morning and can't wait to get it in.
I'll be building a false floor and going the extra distance to try to build some hatches for storage of tools/etc
"you can also hide your weed in there"
