Installing a paxton novi 2200.
onebadgsx
Houston, TX
I have a convertor that will be ready Friday so I don't know if I want to wait to hit the track after install of that or get a before and after. Got a circle d 3c
stretch
lufkin,tx
ive cut 1.39 with 2c, so if u hook it should awesome.
come to lufkin sat and make all the passes u want.
Trousersnake
I lost about a cup and half of trans fluid cutting and re-routing the lines..
I don't see a dipstick to check the levels or add more..
What would beefcake do?
Trousersnake
All I have left.. I haven't been able to work on it all day been watching the damn kids..
Trousersnake
I'm pulling everything back off and cleaning up some stuff and going back over it..
Plus I didn't lock tight any bolts.
I've been using the iPad online PDF and over looked it
DSargent09
Get iT!
NICEEE... hurry up though damn. The day mine comes in I'm locking anyone who may bug me (fiance) in the closet and knocking it out. Nice pictures... I may look into having a lot of my hard ware powder coated... opinions?
Wnt2gofst
Banned
Columbus GA
Look at trans. On right side it has a metal valve sticking up. Pull it out. It come out just loosen. Actually has a filled mark on it. Add oil there also. Once everything is together. Run thru the gears, let it run some in drive and double check level.
Just Another 700whp DD 5.0
Wnt2gofst
Banned
Columbus GA
And I cut 1.45 with a 4c at an okay at best track with OK prep. With better prep I think it can improve a little.
DSargent09
Get iT!
You can tell its been awhile since you have done this by the pics from your link.
Gas price in the back ground is like $1.80
If I somehow end up free I may try an join.
Trousersnake
Seriously If I had to do it over I would of had beefcake's shop put it on..
The amount of time and uncertainty I've got into this would of made it worth it..
If you don't love working on car's have someone install it..
Its not hard at all but I could of always used an extra pair of hands
