Installing a paxton novi 2200.
cyclerick
why are you taking it out?
Cause I'm installing my Morosso separator at the same time as the Paxton. I will be running both sides of the valve covers to a T connected to the can and then to the CAI and capping the manifold. This method calls for removing the passenger side PCV and replacing it with a connector (same as the drivers side which has no PCV)
stang8psi
Slower,Lower Delaware
Not sure you guys are using the moroso for it intended purposes, its a one way oil seperator not a catch can. To do what you are trying to do you have to get a true catch can that is vented. Otherwise you are pressuring the system when in boost and vacuuming when not in Boost. The pass side pcv is to make sure the engine is performing this correctly, your main focus should be letting the engine do this while eliminating any oil blow by, not changing the pressure and vacuum operation.
bhowardb
YellowBlaze
What's the trick for removing the passenger PCV valve? It looks like the fitting to the valve cover should twist off except there are 2 tabs which are locked into the valve cover. I don't want to break it off. What gives?
Put a wrench on it and turn it. It won't break. Just took mine out and replaced it with one like what's on the driver side. No PVC.
Wnt2gofst
Banned
Columbus GA
I left my blue fitting in. Connected hoses to them. Vented to atmosphere
Sent from my SAMSUNG-SGH-I777 using Tapatalk 2
bhowardb
YellowBlaze
Mine is vented to the atmosphere. No pressure or vacuum.
cyclerick
How did you vent your Morosso? I see you connected the passenger and drivers to a T, then to Morosso. Is your other fitting on the Morosso left as a vent or did you modify it?
Wnt2gofst
Banned
Columbus GA
Left as a vent. No different then putting filters each side like some do. But I've seen people have issues of oil soaking filters after a while.
slvr08gt
Vilseck, Germany (Rose Barracks)
Recieved my kit today.
Paxton 2200SL Tuner Kit
ID1000's
JLT Intake
Canton Expansion Tank
Vortech BAP
3.8 and 3.48 Pulleys
NGK 6510 Plugs
Tial Q BOV w/ Adapter
Now if I could just get my car running they way its supposed to. FML
Trousersnake
Haven't driven it yet underboost doing a datalog 6:30 with a partial throttle and 10 minutes of driving
