I just ordered a custom geared Magnum, wish me luck!
Good luck!
+1 on the "what gears" question.
2.29
1.6
1.21
0.54
It will suck on the strip but I really don't care about that, think it will shine on an NA or a centri on the street/track, and as I don't know which way I'll take with the car once I take the turbo kit out, chose this. I hate my current 6060. Actually is the thing that I hate the most of how the car is as of now.
2.29
1.6
1.21
0.54
What rear gear you have in there?
?What is going on with your 6060?
I have 3.73 because of the turbo and a tall tire but will switch to 4.10 or 4.30, after I test the car NA and with the transmission as it sits. I will have the gears in stock so to decide.
Mine is one of the first that tremec delivered as a kit thru D&D, 2nd never worked right. With Redline's MTL more or less works while hot. Cold, it just does not work.
Is it one of the slightly oversized input shafts the first GT500s were plagued with that made a quick shift to 2nd hard to do?
Maybe, you have a link to the solution? I already got the 1-2 synchro and fork to give to the guy who will buy it after I take it out, would like to correct everything out or give the complete picture to the new owner.
No link. It was something I came across while researching prior to doing mine. Tremec even changed the part number for the better transmissions. The Ford fix was a new transmission.
It might be as simple as crocus cloth on the clutch hubs. The oversize was very small but it was just enough to bind the 1-2 shift. Ford also speced a special blue Teflon grease for the shaft to help the clutch slide.
We did not used the "blue stuff" but used some weird stuff we got with no improvement as when I went to install my trans, the issues started to pop all over the place. Weird thing is that once it is hot, it usually works most of the time.
Red Line MTL!!??? Why did you not use Red Line D4...which is what is speced for the TR3650, TR6060, and T-56M XL...?
I did not like the D4 in my T-56M, when it was cold, it was horrible. Mobil 1 is much better when cold.
Tremec used to spec Syncromesh for their manual transmissions, now they spec Mobil1 synthetic ATF (minimum requirement is Mercon III).
Hmmm. Mine didn't like RP fluid once it started to get cold out. Replaced it with Castrol atf and it's good all the time but I still shift into third slowly on cold mornings.
You will soon have the epitomy of Mustang transmissions. I'd imagine it's going to cost more than usual with all the customs fees and hoop jumping required.
Any idea of how long it will take to clear customs and get to you? What clutch are you going to use?
2.29
1.6
1.21
0.54
2.29
1.6
1.21
0.54
why 2 overdrives lito???
What made you decide to do so low on the 1st gear
You will be able to go like 50 some MPH in 1st gear
Oh I thought you had custom gears made, not purchased a set of gears.
