Installing a paxton novi 2200.
Bigmack2012Gb
Roll Racer
Monroeville,Pa
So my bypass valve thing is fluttering under high revs instead of making the swoosh sound. Is something wrong or am i just a paranoid retard?
gizmo5
Italian between my legs
The valve that comes with the kit is too small. Fluttering is bad and you need a bigger valve. I replaced mine with TiAL valve and its been perfect ever since
Sent from your moms room...
Trousersnake
Will it cause any damage? Mine flutters like a m-fer..
But I would rather do other things if its not hurting
Wicked97
Beltsville, MD
i wouldnt say it would cause damage. Its just a little undersized for the amount or air the 2200 flows. once you crank up boost we have seen them push out the o ring causing a boost leak
gizmo5
If you have a BOSS or a Track Pack car, I HIGHLY doubt the Big Red valve will fit in there without custom pipes.
Wicked97
Beltsville, MD
We are making the pipe to fit the 90 under the stock pipe with the BOV. i have it on a boss right now with all the track pack stuff so it will work no problem! We will have a block off for the stock BOV for guys with high boost
:beer:
gizmo5
That makes sense. Paxton put the valve in a stupid ass spot. lol.
My Q valve barely fits in there lol
Wnt2gofst
Banned
Columbus GA
:beer:
So are you deleting other one completely?
from my S4 in your sisters bed
Bullett
Pwnisher
Mission, TX
Bewzt Killz
gizmo5
That's officially 3 dead paxton coyotes in the last few months. Same setup, same boost, and all 600-640whp
Maybe its a 2013 thing. I'm confused
Wnt2gofst
Banned
Columbus GA
Ya I wonder if its the slight changes the engine got from the 11/12 to the 13's. Or so.e thing in pcm not reflecting in tune.
I know a hand full of 11 and 12's that have been on 10-12lbs for a while no issues. 2 tuned by one shop both at the 680-713whp plus bunch on other forums and FB in the 600-650whp no issues. Most them being 11-12's also.
gizmo5
Good thing my new engine is a 2011 block with the bigger main and superman guts lol
stang8psi
Slower,Lower Delaware
Mine is a 2011 lol and it didn't last 2 months ... 640-660rwhp and couple of pulls and than crop duster mode kicked in lol, these supercharged cars popping #8 and #6 are becoming more and more the norm.. interesting isn't it?
Bullett
Pwnisher
Mission, TX
I'm about to rebuild it. Going to throw the boss rods and pistons, crank, head changing kit, valve springs, and oil pump gears. I just need the part number for the boss crank bearings.
