The Offical Jegs 15" Wheel Thread
kbchevlvr
ok...no pics, but i did test fit the wheels. the rears for sure need NO spacer. the fronts i was able to make work with a 1/4" spacer. i did not need a 3/8". so it saved some of the threads on lugs.
chad05gt
Lake Charles, La
Did you drive around? What tires?
With 27x10.5x15 ET Streets... the little movement in the axels made me uneasy, and I just ordered the 1/4 spacers just to be sure...100$ for piece of mind, over a new rear end, downtime, etc... I drove around on mine and 'scuffed' them... No problems ZERO!
SlvrS197
Do you need to use tubes for a 27 or 28 inch et street on these 15's???
joedls
Dragracer wannabe
Lake Forest, CA
Stock studs are 3" long.
Just swapped out the front wheel studs. The stock ones are actually 2.25" vs 3.315" for the new ones. I'm not sure the lug nuts I ordered are gonna be long enough for my street wheels. And I probably won't get to try them out tomorrow. I'll be in Pomona all day at the swapmeet.
black05stxjt
anyone try the summit drag stars.little bit cheaper and look the same.just curious.
from the research i did prior to buying the wheels....i found that the jegs wheels and summits were both basically knock offs of the old weld pro star xp line of wheels....so i can not confirm they are the same but i would guess they are....i just prefer buying from jegs is why i purchased them.
SlvrS197
Where is the cheapest place to get 3" studs for the front of my car?
Liftedbronco
Shredder
Harrington Park, NJ
2 questions.
will the 15x8 with 4.5" bs fit on the front? Id like to use these on the street.
Also, jegs makes a 15x10 with 6.5bs. The outside lip should not stick out cuz its the same as a 15x8 with 4.5bs. The extra 2 inches in on the inside edge. I gather that you guys say the 10 inch rim wont fit. Why?
