painted center console...,insulated all
samolet
GERMANY
painted center console in Alloy/Black and insulated all:beerchug2:
mfergel
Richmond, VA
How much did you spend on insulating the interior? Really want to do that as well. At some point my carpet needs to be replaced so it only makes sense to do them both at the same time.
samolet
GERMANY
Thanks Guys! ...the work has really paid off. The heat from the gearbox / engine remains outside. The doors are now closing like a luxury sedan. And the OEM Shaker sounds really good. inconceivable.... it is a completely different car become.
You need for the whole car nearly 20 Meter dynamat (65 Feet) without trunk 15 meters. Now I have my spare kicked out to save weight:beer:
2L8IWON
Va Bch, Va
Right on. Did you remove the factory sound deadening?
And was there any issue with interior panels cotton with the sound deadening in there?
NotQuik
I can't drive
Central Florida
Center console looks good.
I did mine in hotrod black a couple years ago after one of my dogs scratched it when she was a puppy.
samolet
GERMANY
which factory insulation? ....no problems. Have the door panels even double insulated! once the door and the door panel! see pictures...
05Torch
Wow that center console looks perfect what did you use to do it?
samolet
GERMANY
Thank you! Grind, adhesion promoter, paint (Alloy), 3x clear lacquer and wax. Done
I think I want to do this sound dreading. What kind did you use?
Looks like Dynamat
2L8IWON
Va Bch, Va
How much do you have invested in this project and how long did it the you?
And no issues with everything fitting with the added material?
Awesome project!
