Flat black oil filter relocation kit
07Bandit
Northern NJ
So, I finally got around to installing this today but the lines coming out of the stock filter location actually hit the sway bar (see attached). Do you have a different set of connectors I could throw on the AN lines that are a 90 or 45 degree option?
Had the same problem when I pieced my kit together. I changed the fittings out of the adapter to 90 Degree 3/8 to 8an fittings. You can pick up the summit ones cheap and solved all my issues with the swaybar. Sorry I don't have a picture handy.
krang00
Allentown, PA
Ahhh, so 3/8 to 8AN will do the trick out of the oil plate adapter then... I'll order a set of those. Thanks for the input 07Bandit! This should really be standard issue for this kit :)
07Bandit
Northern NJ
I used 8an line when I did my setup. Just make sure what size an line you have and order the right fittings.
JeremyH
3V Fuel Guru
Virginia Beach
This kit uses 1/2npt to 8an fittings at the adaptor.
You would just need some 90 degree 8an hose ends for your setup.
Pm sent.
