Installing a paxton novi 2200.
beefcake
Forced Induction Specialist
Official Vendor
Bethel, Ohio
now that you have re clocked the maf, you need to tune the car for the new position
D98GT
STREETCAR
Liberty TX
Okay guys I have both a KB BAP (20a) and the vortech programmable booster (pn 5a102-029 at my house.
I realize that they both would be able to work but which should I use and which should I sell? I'm sure they install nearly the same but I want a trouble free setup. Talk me into one of them!
beefcake
Official Vendor
Bethel, Ohio
if you have the boost reference, use it, it will extend the life of your pumps.
Greg Hazlett
Stepping on the Pink Bus
Official Vendor
Chesapeake, VA
Pumps use the fuel to keep them cool.
Our DIY wire upgrade reduces the fuel pump duty cycle by 20% which will help the pumps life.
MilehighGT
Colorado Springs, CO
I've been trying to track down an issue with the short term fuel trims. Seems that the driver side is running a little leaner. Had re-clocked the MAF and it got better, then worse with a revised tune. Have checked for vacuum leaks and found none. I may have clocked the MAF too far now but trying to track down the reason why the short terms are off is puzzling me. Maybe an O2 sensor?
vic2186
lean codes on start up p1071 p0174..cleared never came back but a lil worried
vic2186
will a jlt catchcan cause vacuum leaks passenger side..causing correction factor
gizmo5
Italian between my legs
If you have a JLT or any other can on the boost side without a check valve.... You're wrong.
CPRsm
No you're wrong Colonel Sanders, Mama's right!!
