Dark_horse
KC MO
Heads and cams torqued down...
Also made sure everything was nice and lubricated...
Joe Gibss assembly grease on the cam caps
Joe Gibbs HVL on cam lobes, rockers and lash adjusters
Sprayer84
Omaha, Nebraska
Oh no, not another one!!!!:soapbox:
My buddy just procharged his 05 and that thing is nasty. Not sure I can go to the dark side though. Without it at least being a Z
Are you old enough to drive a yellow one? You know you need a shit load of white hair...
The only ones a like are, black, copper and yellow. Never owning another black car and the selling price on copper ones is freaking crazy.
Bad06stang
Las Vegas, NV
painted my coil covers to match my DIB
Bad06stang
Las Vegas, NV
thanks man! I did some touch up work on the white this morning and put another coat of clear on it but this time i put a few runs in it... Gonna spend a few hours wetsanding and buffing I guess lol
Fabman
Children Of The Corn
Pleasanton, Ca.
It looks awesome...you must have one hell of a steady hand to brush paint the white in there like that. It looks totally factory.
onehotpny
Aragon,Ga
actually it's easier to paint the letters when they are in set ,than it is when they are out set. the paint will actually flow into each letter. just have to make sure to not use to much paint in your brush at a time. old sign painters trick. still good job..
Kalatrax
Albuquerque, NM
Did this a while back but figured I would throw it up. After I did my CMPD's with some naval epoxy it failed. So here it is tig welded and ground down. Only cost $3 for the aluminum rod and paid a friend $50 to tig it.
Zodiac
Cary, NC
With the help from Hypermotive I purchased/installed:
Koni Str.t
GT500 mounts
BMR Lowering Springs
BMR LCA relocation brackets
BMR UCA
BMR UCA relocation bracket
BMR PHB
Whiteline PHB brace
Figured it was time for me to start participating in this one. I shall put some pics up this evening.
Greg Hazlett
Stepping on the Pink Bus
Official Vendor
Chesapeake, VA
Koni Str.t
GT500 mounts
BMR UCA
BMR PHB
Whiteline PHB brace
Nice pickup! That will make a lot of handling difference!
