The Offical Jegs 15" Wheel Thread
DarkFireGT
The Jegs 15x8 being used actually has 5.5" BS, not 4.5". As mentioned, to not stick out, the 15x10 would need a BS of 7.5", to have a chance of fitting.
Liftedbronco
Shredder
Harrington Park, NJ
ah, my bad. so then let me echo what was said before. why the HELL doesnt anyone make a 15x10 with 7.5bs? Or if you prefer, why the HELL did ford make our rear end so wide? (insert joke here)
joedls
Dragracer wannabe
Lake Forest, CA
2 questions.
will the 15x8 with 4.5" bs fit on the front? Id like to use these on the street.
Also, jegs makes a 15x10 with 6.5bs. The outside lip should not stick out cuz its the same as a 15x8 with 4.5bs. The extra 2 inches in on the inside edge. I gather that you guys say the 10 inch rim wont fit. Why?
The 15 X 8 on the rear needs to have a 5.5" BS, not 4.5", to not stick out. That's why the 15 X 10 needs a 7.5" BS.
joedls
Dragracer wannabe
Lake Forest, CA
Just swapped out the front wheel studs. The stock ones are actually 2.25" vs 3.315" for the new ones. I'm not sure the lug nuts I ordered are gonna be long enough for my street wheels. And I probably won't get to try them out tomorrow. I'll be in Pomona all day at the swapmeet.
While I was at the swapmeet in Pomona I got some longer lugnuts just in case. I'm glad I did. The ones I ordered from Summit (1.9" long) were too short once I removed the 3/8" spacers and put on my street wheels/tires.
06GT_Vert
Still Stock
Cypress, Tx
15x8 Jegs will NOT fit the front - Caliper is way too big - You could NOT grind it down enough.. I tried too
Dex
I'm Dexolishous
Utah
the V6 wheels will but they are 7" wide. Im sure a 16" wheel is just as big as a pain in the ass to fit. Im tryin out some 15x8 and 15x10 prostars out tomorrow. b/s looks like it may work
SlvrS197
Just ordered my fronts and rears for my 07. will post up results and pics afterward.
firestang70
SW Ohio Ninja
Well i picked up my rims yesterday. I swapped my front brackets and rotors to the 4.0 pieces. It does free up some room. I still did some grinding. Still rubbed. I measured out washers 1/4" for spacers, no rub with some room to spare. With more aggressive grinding I may have got them to work w/o spacers. I did not want to grind them too much. It appeared ( I was tired though) that rim was tucked inside the fendr. I will also post some pics when the tires are mounted.
Dale
Liftedbronco
Shredder
Harrington Park, NJ
for the record, i did a little snooping. Weld prostars also make a late model f body wheel. 15x10 7.5bs 5x4.75. They look like they could be drilled for us. Anyone wanna call?
Freaknazty
KEYBOARD NINJA
SOUTH LOUISIANA
i got there number you wanna try lmao they have been supposed to be released for over a year and every time i call i get a different excuse
