CandyRedGT
Excellent info here!!! Thanks alot for posting it! Since TCI DID finally send a new tranny/convertor..i'm trying my 5R55S again....if/when it fails again...i'll do this swap. Thankyou, Joe
When converting from a 5 speed to the AODE, I will need to purchase the trans control module and wiring correct?
OP, you mentioned that on your THP you had to have some pipes modified by Jim. Which pipes were modified for the install?
And how do I get in touch with Darrin? The website link you posted for BC automotive doesnt work. Thanks.
call him at 317 514 0816
Tell him you talked with me ( Dave Lewis)
You either need to get a device to shift for yu or you can buy a manual valve body and do all the shifting yourself.
Can tremeber on the pipes...its been years
Well...you've got a lot of questions there...
To the best of my knowledge I thought you need to have a manual/stick pcm for it to work properly with the 4R70W. What did Lito say about it since he did the tuning on my car as well as Paul(againstallodds1) which we both have manual PCM's.
Paul and I used the OSS output from the trans right to the same wires that were used in our 3650 transmissions so I can't really help you there.
As for the trans brake it will only engage when the trans is in first gear. There are a lot of people who use the button on the shifter for their trans brake .... make sure the button is rated for at least 10 amps but preferably 20 amps.
You will also need to make sure there is a micro switch built into the shifter for when you put it in reverse since you have to actually engage the trans brake for reverse to work.
Just read the link to PA, thank you. The pigtail that is currently on the trans has 3 wires. Yellow/white for transbrake, yellow for converter lockup and pink/black for OD.You will need to wire up a switch somewhere to do that as well as for the overdrive since they are both electronic.
I don't know what dust cover you are talking about. I was able to use the separator plate from my 3650 and I just cut it where I needed to so it didn't stick out below the trans.
Also wonder if instead of removing the sjb as the OP did to find those two wires if I could not just locate them as I "think" those two wires to the reverse lights run under the rocker panel cover on the passenger side. Just cut and cap SJB side and run my power wires somewhere over there?
My relay idea starting to sound like the way to go. I already have a painless add-a-circuit installed with 3 constant hot terminals not used. I located that just under the passenger dash so that is easy to get to.
You've probably already read through it but FB transmissions (Freddy Brown) has a pretty good write up on 4R70W conversion in their technical advice section.
If you are doing this and planning on getting serious in drag racing do yourself a favor and don't use a relay to activate the trans brake.
You should just see if there is a place that a micro switch can mount to the hurst shifter. ...
You actually want two micro switches on your shifter so that one will be your park/neutral safety switch for starting the car and the other for reverse.
Lastly, my transmission also doesn't have the VSS sensor in it...that port is just blocked off so I'm also no help there.
Crown, My transmission went in this weekend and we used the MLPS for the reverse lights and the neutral safety switch. We were not sure if it would work but it did work. They told me one of the reverse lights was out, so it could be a bulb or more wiring will be needed. When I find out more I will let you know.
Also I was told that a manual transmission tune can be flashed into the computer on the 05/06 cars and it should work. I'm sure Lito will have no problem with this.
I would be leery of using an ssr just for the reason that when they fail they usually fail in the closed position. I have read up quite a bit on relays when building my powder coating oven and that was the biggest complaint with the solid state relays. The last thing I would want would be for the trans brake to activate when down shifting the car at speed!!!
