A John In NJ
Rice Cooker
Hello all,
So I got the P0340 DTC, Cam sensor, and from what I read its because of the alternator. Ok So I changed the alternator to a PA alternator and the bigger gauge wire. I then returned the ecu back to stock and then reloaded the a strategy tune (Since I dont have a custom tune yet). The only adjustments I made are the axle ratio and neutral idle (870).
I turned the car over and it idles normally for about a min then it slowly drops under 750 with a weak semi rough idle and the car shakes a bit and the lights dim. It continues to drop very slowly till it eventually shuts off.
the only mod I have is the JLT 3, which I put in the strategy tune.
Any ideas?
Any ideas?
