The fact of the matter is that I know I don't know a lot of things. I usually have a general concept that I've developed before, and then I ask A LOT of questions from there on out. It's how I learn; conversation and through doing it. I ask a lot of questions about things because questions are cheaper than parts, and I've been in many a situation where asking a question has saved me a broken something down the road.
Yet you seem to ignore good advice.
The impression I get from conversing with you is that you aren't listening to what people say. You are just waiting for them to finish talking so you can add your $.02.
You will either think about that or you won't. Want to know what my money is on?
The goal of this isn't to get something cheap, at least not in my book. It's to have the best parts (usually custom made) for a bit less than it would cost you from a shop.
In most cases custom made is not as good as mass produced. The only real advantage custom made has is that it will get you stuff that is not mass produced.
And custom parts for a "bit less" is an oxymoron.
I'll have to check around and see if there are any good write ups on harmonic balancer pulley design. Proooooobably not on this forum though lol.
Probably not anywhere. Designing/making a harmonic balancer is just plain stupid. How would you even test it? Wait to see if the motor broke?
Not to be rude here, and correct me if I'm wrong, but if I know anything, it's alternator pulleys. It was quite literally my job.
Remy owns 51% of the aftermarket alternator stake in Auto Zone, Orielley's, and Advance. I designed pulleys for over 300 applications, one of which is the 6G alternator for the S197.
To design a pulley you need your diameter over balls, groove offset for alignment with the belt, fan offset so you clear the frame, shaft diameter, number of grooves, hub length, etc. to be able to design the pulley, plus any unique dimensions like for odd offsets and so forth.
I was talking about designing other pulleys aside from a clutched alternator pulley. The reason I assumed that was I can't imagine for one second why anyone would want to make their own custom clutched alternator pulley when they can simply buy a mass produced one that is for all intents and purposes perfect. Designing/making a clutched pulley is a galactic waste of time and money.
Now, many of those dimensions you could pick and choose if you were designing the entire pulley system; I agree with you there. What I'm saying is that I would need probably 5 OEM pulleys so I could measure then and figure out what the specs for the OEM pulleys are. Once I know what OEM spec is like I can work on modifying it. That's what I meant by saying I need 5 different pulleys to get specs. I would be more than happy to take a screenshot of a pulley design to show you just how many dimensions go into one; or at least how I was taught to make them.
Your going to modify a clutched pulley? First off why? Second off you think you can come up with something better?
I'm merely talking from my own experience.
What experience? You lost me. Everything I am hearing says you lack experience. What have you designed, made, tested and used long enough to prove the design sound?
Your talking about converting your car to a 8 rib setup right? Why design or custom make anything? Every single part you need to make it happen has already been designed, tested and is mass produced. Custom stuff will cost you more money/time and will most likely not be up to the quality of the stuff you can have sitting on your doorstep in 1-3 days. I don't get it.
We have the ability to custom make just about anything. But we don't waste our time/money on re-inventing the wheel.
Headers, we can custom make those no problem. But we buy them.
8 rib conversions, we can custom make those no problem. But we buy them.
Caster/camber plates, we can custom make those no problem. But we buy them.
Control arms, we can custom make those no problem. But we buy them.
Fuel rails, we can custom make those no problem. But we buy them.
Multi pump fuel hat, we can custom make those no problem. But we buy them.
Etc
Etc
Etc
Etc
Some day hopefully you will understand that time is truly money. And it is not to be wasted. Apply your talents where they will reap benefits. Not re-inventing the most simple of widgets. Just because you can do something doesn't mean you should.
