Back@itagain
Rhetorical?
Pretty much...but at this point probably the best/easiest place to start.
Rhetorical?
They flow a significant amount of more air than the stock heads. They do come with stock springs though. It's around 20% more air. I have a set of almost new 2009 stock heads I'll trade you for, lol.
I dont recall if the last time you removed your plugs they had any oil in them.
If a guide issue and if you have a borescope that fits, you can remove the injectors and look thru it for closed intake valves and if some oil is pooling there.
FRPP Stage 1 heads...pretty much stock heads.
My heads are stock (valves)...but have cams and springs.
Is there a way to service the valve stem seals without R&Ring the heads?
So FRPP has 3 options of heads for our 3Vs.
Option 1
M-6049-N3V and M-6050-N3V = direct replacement for 2008-2010 Mustangs with 12mm plugs.
Option 2
M-6049-N3VPA and M-6050-N3VPA = CNC ported:
-53cc combustion chamber (stock is 51cc)
-Intake runner vol 202cc (stock 174cc)
-Exhaust runner vol 73cc (stock 62cc)
Option 3
M-6049-463VP3 and M-6050-463VP3 = CNC ported:
-48cc combustion chamber
-Increased intake valve size 35mm (stock 34mm)
-Increased exhaust valve size 38.5mm (stock 37.5mm)
-Intake runner vol 214cc
I have option 1...stock heads.
I guess maybe I shouldn't refer to them as stage 1 heads...?
Thats what they were referred to in earlier FRPP catalogs.
Sorry for the confusion...
So what do you think Bruce... Will R&R the valve seals (upon confirmation that they are leaking) be doable without R&R the heads nor cam like in the Ford service manual?
Have you ever done anything like this? The good news is that I still have my old engine which I can practice on before doing the real thing. lol
If you buy a valve spring compressor do yourself a favor and get the Freedom Racing version.
Can these threads be merged? I am following this but it is getting a little confusing going back and forth. Both threads seem to have come to a common ground, maybe just use one going forward?
Hey I have one
Gerald,
Please keep it to one thread.
