lethe
V4g!n@ #er
Everett, Wa
Started it and made a short sound clip video then pondered about where to mount my catch can.
LAStang1234
----------DSL----------
Little Rock
Blew up the inside!
Sent from my iPhone using Tapatalk - now Free
GoneFord
Yorktown VA
Curbed my rims rather than allow my steed to be sideswiped by a full sized pickup truck. Braked hard and turned left when I realized the idiot was going to take over my lane.
Front
Rear
It happened at 0530 on a round-about with no one else around. I didn't even get his license plate as he was to the right. Wouldn't have mattered anyway - my word against his and he suffered no damage. And I didn't chase him down knowing if I did I'd do something that would cost me a lot more in the long run.
Worst part is I can't replace these. They're 12mm offset and clear my Brembos. Can't buy them anymore - the one's available now don't clear the big brake systems.
weather man
Persistence Is A Bitch
MN
^^^^ Check around, there are wheel repair places that can fix that easily.
tigerhonaker
TN
GoneFord
You can get those wheels redone.
I worked for Dealerships for over 16 Plus yrs. and we had many wheels repaired.
Those guys travel the dealerships so all you have to do is find a dealer you know and see who they use.
Then give that person a call and set up a time for them to do it.
They are mobile so in some cases they can actually come to where you are.
Terry
GoneFord
Yorktown VA
Thanks guys. They are such beautiful rims and the number of compliments I've received are innumerable. Having a machined lip (fine lines rather than a perfectly smooth surface) I'm concerned how a grind and buff would appear. They're clear coated to boot.
But it's better than the alternative so I'll see what I can find around here for repair options.
zombie_medic
Escalon/Modesto, CA
just put on the flowmaster American thunder axle backs and Jegs cat delete pipes. blow away with how it sounds! hoping the 3" over axle pipes and H pipe add to it like I'm hoping!
Rasmus
Relocated the Mustang to the detached garage. At least it's the same color.
