10.0's in the 5.0
POINT
The bay
I don't post much on this forum but I just wanted to share my 13' 5.0 build. Basically it's s stock motor and trans, supporting mods, 82mm, E85 and circle D. The car made 676/566 when it was all said and done, and of course a BADASS AED tune, I can't say enough good things about the boys at the shop, they really take care of there customers! The car is an absolute beast on the street and track and I have my sights on 9.99, BIG THANKS TO AED, CIRCLE D, FORDRACING.....and the WIFE!
Check out the build on RACEPAGES and specifics on the 5.0 starting on pg90
http://76.164.129.182/PROMEDIA/RP_0114/mobile/index.html?id=90
GoPro of the pass
http://www.youtube.com/watch?v=mKNGat6i5k4&feature=share&list=UUhN89-yd1QrNfsRIDOtioew
racksteris
That's nice man, Are you concerned with the stock motor and that high HP.
I have almost the same HP on my stock motor with a Vortech and I'm alittle worried.
POINT
The bay
I'd be lying if I said no, but running e85 helps to cool the engine down to help avoid detention, I've ran 50+ passes so far with no issues, once we get into the 9's I'm turning her down for longevity:)
What gears are in this car?
BONE STOCK 3.15
POINT
The bay
And that's a rap! AED FTMFW!!!
9.99@135!
badnews
North Florida
Impressive. With an 82 mm, how much boost are you seeing? Stock driveshaft, race weight, etc? Injectors?
POINT
The bay
With the 82mm I'm seeing 10-10.5#,Dynatech D/S, 3700lbs, and running ID1000 with E85
KrisR
Wyoming, MN
Very nice. Sounds like the 1-2 shift is a little earlier than the rest...maybe leaving a little on the table there? Unless it was bumped up after the video was shot....
POINT
The bay
KrisR
Wyoming, MN
hmm, rev is set a 7200-7400k not going *ANY* higher than that as I'm still on stock oil pump gears, but its moving out nonetheless:)
Have you datalogged it to see where it's actually shifting? It just sounds to me like first gear doesn't rev out as high as the others. I know that if the 1-2 shift is too low it can really kill momentum and affect the whole run. I was just curious if you have confirmed that the 1-2 shift is really shifting that high. Mine was 'programmed' to shift at 7500 but it was only shifting 1-2 at 6800 until my tuner actually got a datalog sent to him and he figured it out. Makes a difference.
Nice passes regardless. I don't mean to take anything away from that.
POINT
The bay
I actually haven't data logged it yet, I'll defiantly give it a shoot next out, thanks for the input!
