Sweet
I figured that's why you went thru all that extra trouble to raise the line pressure. You couldn't get the car to even hold back an N/A car could ya?
It hit gears like my Terminator used to with a PA Pro-Mod C4I figured that's why you went thru all that extra trouble to raise the line pressure. You couldn't get the car to even hold back an N/A car could ya?
All bullshit aside I you don't ruin any engines from raising the line pressure in the tranny
Otherwise have at it. My panda fu is weak lolWell sure. It was bound to happen whenpeople know it can be done, and they're not completely wasting their time. It was really just a matter of time. I had been talking to a few places about selling them because I just don't want to.I like the fact that everyone is getting after it with the brake.
I just watched the video of Chris' green car again, and it sounds to me like its still foot braking, trying to get the right rpm for launch? Right before it launches, I hear the rpms try to push a little more.
And that's not a jab Dustin, just an observation. Normally with a brake, you go wot with the pedal, and it's done. The green car just doesn't sound like that, you can hear the rpms creeping the whole time.
Everyone laughs when they don't understand the purpose lolNice!, but you're really mad at "magic boxes" aint you?![]()
I go WOT in my car and it will flash on the brake and then as it spools, making more power, rpms creep up until it hits my 2step. That is just how things work in a turbo car that continually makes more power with load and time. Some people also stall against the foot brake to build a little pressure before lighting the 2nd bulb and grabbing the brake to make things quicker/easier.
Curious to see how the 6r80 holds up to brake abuse at big power levels
Google thrust bearing problems on mod motors
you can have line pressure too high. Google thrust bearing problems on mod motors w aftermarket trannies. Especially glides and 400's. why do you think MMR makes a rollerized thrust bearing for mods?
The brake thing is cool and I've been reading every post in all these 6r80 trans brake threads and I just don't understand the hate Kris. You got a problem with dustin...fine, but the fact of the matter is he figured out a brake... so did u. You are obviously smart...u ruin it with your constant hate of everything that's not Lund tuned or faster than ur car. If dustin wanted to sell something he came up with, why not... its the same as tuners selling there tunes. If he wants to sell it only to his customers why not... afaik Lund won't even tune a turbo coyote unless its his kit. If you want to give away ur time and effort for free have at it.... but just know Dustin is not the only person on here trying to sell something. is there something I'm missing? Or is it really just u hating on him because he supposedly can't produce a car as fast as your n/a car? I'm curious....
Yes line pressure can cause issues with these motors and thrust bearings. I had it happen to my car. I have a thread about it that is in the 2005 tech. My trans cooler lines were restricted and caused higher pressure and it did major damage to my crank, block and chewed up the thrust bearings.
http://www.s197forum.com/forum/showthread.php?t=62947
Sent from my SAMSUNG-SGH-I337 using Tapatalk
Your lack of understanding on the basics doesn't make it FUD. How will it better myself to knock your design if I still won't sell mine?Ah, a classic strategy. If nothing else, spread the FUD in order to better yourself.
FUD=fear, uncertainty, and doubt in case anyone doesn't know.
Yes line pressure can be too high but that has nothing to do with crank thrust bearing.
Now a ballooned converter or improper bellhousing indexing or bellhousing depth can cause thrust damage just like a improperly installed clutch or damaged input splines and clutch disc binding on a manual trans.
The aftermarket trans crank failures are 99% due to improper bell housing indexing or over powering a tq converter and it ballooning against the rear of the crank
With a cast-on-trans bellhousing on the 6r80 and a billet converter like circle d there should be no damage to crank thrust by the trans regardless of line pressure.
Sent from my iPhone 5S
The transmission naturally tries to push out the converter because of the fluid and pressure in it coming from the tranny. As that pressure goes up, so does the push on the converter. T400's are known as crank killers for this reason.
Line pressure does not equal converter pressure. More FUD.
