Wlkn Tal
Got the 4.0L on, and dyno'd it.
The plan was to put this on now before building the motor so I could compare it directly to the 2.9L with no other changes. Everything is the same as with the 2.9. Same tune, same dyno, same everything except the blower itself.
Unfortunately, I didn't have a large enough pulley to keep the boost down to 23-24lbs as with the 2.9L, so it is making about 1.5-2 lbs more boost than before. With that considered, the difference is still very dramatic. It feels like a very different car.
It made 874/800 at the wheels on 25lbs (15% lower + 3.5" upper), 19 degrees timing, and 100 octane + torco, stock motor. The biggest gain was the torque all through the RPM band, which is exactly what I was looking for. I always felt the 2.9L didn't quite make the torque I wanted it to. So I gained 50rwh and 111rwt with just the blower swap.
Next up is a built motor and nasty custom cams. I'm expecting another 80-120rwh from the cams and higher RPM capability.
Here is the graph showing the 2.9L numbers (in green) and the new 4.0L numbers:
I'm amazed it didn't window, I've seen a few come apart at 800 hp
